Bearloverpr 14 Posted June 14, 2021 Posted June 14, 2021 (edited) Since the latest update 4.6.2.0, the emby lost the ability to show the posters on the home screen, but it only affects ultra wide monitors. Any Idea? Edited June 14, 2021 by Bearloverpr
Carlo 4561 Posted June 14, 2021 Posted June 14, 2021 Hi, what resolution are you running on the ultra wide monitor? What happens if you narrow the web browser?
Luke 42203 Posted June 14, 2021 Posted June 14, 2021 Can you please attach the emby server log from when you tried to pull up those images? Thanks.
Happy2Play 9802 Posted June 14, 2021 Posted June 14, 2021 Do you get the same if you cleared the browser cache?
Bearloverpr 14 Posted June 15, 2021 Author Posted June 15, 2021 This happens every time I open the emby window, tried deleting browser cache, installed other browsers still the same, it goes away if the resolution of the browser window is 1080 or lower but if I extend the browser window to the full ultrawide, the images look low quality and if i refresh with the full size some posters gain quality but most of them disappears . My monitor resolution is 3440 X1440 Server logs Attached. logs.zip
Happy2Play 9802 Posted June 15, 2021 Posted June 15, 2021 Nothing is standing out to me. Do you see the same when you enter each library? I even emulated that screen resolution and Emby reprocessed all images and appeared for me. Have to wait and see if Luke sees something.
Deathsquirrel 745 Posted June 15, 2021 Posted June 15, 2021 It's not a resolution issue as my main monitor has the same native resolution and I don't have this in chrome, firefox, or edge.
Solution ebr 16309 Posted June 15, 2021 Solution Posted June 15, 2021 One thing I can think of is that you could have "broken" images in your cache and, when you make the browser a certain size, that lands on those broken cached images (we cache images at display resolution). So, you might try clearing your browser cache and also your "imagecache" folder under your Emby folder. 1
Carlo 4561 Posted June 15, 2021 Posted June 15, 2021 I think what @ebr just mentioned with clearing the imagecache will be the ticket to fixing this.
Bearloverpr 14 Posted June 16, 2021 Author Posted June 16, 2021 (edited) Thanks guys for all your replies. A. The problem is only on the home page, B. I don't have any custom CSS. C. it happens on any browser I installed. Edge, Firefox or chrome Also, Can you point me on where is the emby image cache folder? didnt find anything called "imagecache". I'm from the media Browser era and don't have a folder named emby on my \AppData\Roaming and the only cache folder contains more stuff than just images. The main folder of my installation is called "MediaBrowser-Server" Edited June 16, 2021 by Bearloverpr
Carlo 4561 Posted June 16, 2021 Posted June 16, 2021 Try this area: C:\Users\YOUR-USER\AppData\Roaming\Emby-Server\programdata\cache\images
Bearloverpr 14 Posted June 16, 2021 Author Posted June 16, 2021 (edited) 4 hours ago, cayars said: Try this area: C:\Users\YOUR-USER\AppData\Roaming\Emby-Server\programdata\cache\images Awesome! That worked The location was: C:\Users\USER\AppData\Roaming\MediaBrowser-Server\cache\images Thank you Guys for all the help! Edited June 16, 2021 by Bearloverpr 1
