RoyH 12 Posted June 21, 2021 Author Posted June 21, 2021 Now that I have the CPU - Intel Core i5-11600K Rocket Lake 6-Core 3.9 GHz LGA 1200 125W BX8070811600K M2 SSD - 1TB 980 PRO PCIe 4.0 NVMe RAM - G.SKILL Ripjaws V Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 Will look for a motherboard to work with them tonight as the original one I choose will not support these effectively.
Carlo 4561 Posted June 21, 2021 Posted June 21, 2021 I think you're going to be a happy camper once you get this setup!
RoyH 12 Posted June 22, 2021 Author Posted June 22, 2021 (edited) This is my final draft any comments or advise would be welcomed before I purchase this weekend. Its way over budget (around 1K for the 5 items below), I dropped the RAM to 16GB to save a few bucks as I was advised 32 was not needed. I have a new 700W power supply have to check and see if it supports the connections for the MB. My only concern really is the Motherboard will it optimize the other components, is it lacking in anyway or is it overkill? CPU - Intel Core i5-11600K Rocket Lake 6-Core 3.9 GHz LGA 1200 125W BX8070811600K M2 SSD - 1TB 980 PRO PCIe 4.0 NVMe CASE - Fractal Design Define 7 Black Brushed Aluminum / Steel E-ATX Silent Modular Mid Tower RAM - G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 F4-3200C16D-16GVKB MOTHERBOARD - MSI MAG Z590 TORPEDO LGA 1200 Intel Z590 SATA 6Gb/s ATX Intel Motherboard Edited June 22, 2021 by RoyH
RoyH 12 Posted July 19, 2021 Author Posted July 19, 2021 Hi, I am finished with my new server rebuild and still have the freezing issue once it is transcoding, it seem to have a huge buffer but still freezes when I look at a movie on my phone when not on wifi. and this is not even a 4K movie My server windows 10 CPU - Intel Core i5-11600K Rocket Lake 6-Core 3.9 GHz LGA 1200 125W BX8070811600K M2 SSD - 1TB 980 PRO PCIe 4.0 NVMe, 3 x 4T HGST HDD, 2 x 8T WD Gold HDD CASE - Fractal Design Define 7 Black Brushed Aluminum / Steel E-ATX Silent Modular Mid Tower RAM - G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 F4-3200C16D-16GVKB MOTHERBOARD - MSI MAG Z590 TORPEDO LGA 1200 Intel Z590 SATA 6Gb/s ATX Intel Motherboard I also have a second issue the Collections tab some of the Box set cases images are not populated I have the Auto Box Set installed. embyserver.txt ffmpeg-transcode-fcd870a6-0e81-4174-8265-8c90daf889a9_1.txt
speechles 2062 Posted July 19, 2021 Posted July 19, 2021 (edited) It is those 32 subtitles. Do you need that many? Spoiler {"Codec":"subrip","Language":"chi","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"Traditional","DisplayTitle":"Chinese (SUBRIP)","DisplayLanguage":"Chinese","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":32,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"}],"Formats":[],"Bitrate":15343139,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false}{"Codec":"eac3","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","DisplayTitle":"English EAC3 6 ch (Default)","DisplayLanguage":"English","IsInterlaced":false,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"subrip","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"Forced","DisplayTitle":"English (Forced SUBRIP)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":false,"IsForced":true,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"English (SUBRIP)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"SDH","DisplayTitle":"English (SUBRIP)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":4,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"ara","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Arabic (SUBRIP)","DisplayLanguage":"Arabic","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"cze","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Czech (SUBRIP)","DisplayLanguage":"Czech","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":6,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"dan","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Danish (SUBRIP)","DisplayLanguage":"Danish","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":7,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"ger","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"German (SUBRIP)","DisplayLanguage":"German","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":8,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"gre","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Greek, Modern (1453-) (SUBRIP)","DisplayLanguage":"Greek, Modern (1453-)","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":9,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"spa","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Spanish (SUBRIP)","DisplayLanguage":"Spanish","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":10,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"spa","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"European","DisplayTitle":"Spanish (SUBRIP)","DisplayLanguage":"Spanish","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":11,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"fin","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Finnish (SUBRIP)","DisplayLanguage":"Finnish","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":12,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"fre","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"French (SUBRIP)","DisplayLanguage":"French","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":13,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"heb","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Hebrew (SUBRIP)","DisplayLanguage":"Hebrew","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":14,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"hun","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Hungarian (SUBRIP)","DisplayLanguage":"Hungarian","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":15,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"ind","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Indonesian (SUBRIP)","DisplayLanguage":"Indonesian","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":16,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"ita","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Italian (SUBRIP)","DisplayLanguage":"Italian","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":17,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"jpn","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Japanese (SUBRIP)","DisplayLanguage":"Japanese","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":18,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"kor","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Korean (SUBRIP)","DisplayLanguage":"Korean","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":19,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"nob","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Bokmål, Norwegian (SUBRIP)","DisplayLanguage":"Bokmål, Norwegian","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":20,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"dut","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Dutch (SUBRIP)","DisplayLanguage":"Dutch","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":21,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"pol","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Polish (SUBRIP)","DisplayLanguage":"Polish","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":22,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"por","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Portuguese (SUBRIP)","DisplayLanguage":"Portuguese","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":23,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"por","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"Brazilian","DisplayTitle":"Portuguese (SUBRIP)","DisplayLanguage":"Portuguese","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":24,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"rum","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Romanian (SUBRIP)","DisplayLanguage":"Romanian","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":25,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"rus","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Russian (SUBRIP)","DisplayLanguage":"Russian","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":26,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"swe","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Swedish (SUBRIP)","DisplayLanguage":"Swedish","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":27,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"tha","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Thai (SUBRIP)","DisplayLanguage":"Thai","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":28,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"tur","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Turkish (SUBRIP)","DisplayLanguage":"Turkish","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":29,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"vie","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Vietnamese (SUBRIP)","DisplayLanguage":"Vietnamese","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":30,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"chi","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"Simplified","DisplayTitle":"Chinese (SUBRIP)","DisplayLanguage":"Chinese","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":31,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"subrip","Language":"chi","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"Traditional","DisplayTitle":"Chinese (SUBRIP)","DisplayLanguage":"Chinese","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":32,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"}],"Formats":[],"Bitrate":15343139,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} Edited July 19, 2021 by speechles
RoyH 12 Posted July 19, 2021 Author Posted July 19, 2021 @speechles Didnt even know it had that many subtitles anyway I deleted them and it actually worked it did not freeze will look at the entire movie later to be sure but it froze like 3 times before in the first 5 mins of the movie I just looked at nearly 10 mins and all good no freezing. I used to run all my movies thru MKV toolnix and clean them up but got lazy and stopped will have to start doing that again didnt realize that subs could do that. Any ideas on my other issue the Box set images.
RanmaCanada 501 Posted July 19, 2021 Posted July 19, 2021 If it is freezing on your phone when you are on data than that would more than likely be your mobile provider throttling your, or your ISP throttling you sending to mobile. It should have nothing to do with the server.
RoyH 12 Posted July 19, 2021 Author Posted July 19, 2021 Dont think it was my mobile provider nor my ISP because it was freezing with all the subs I deleted the subs and its not anymore I cannot look at the entire movie now but will look at it later and see, I will also restore the original movie with all the subs and try that again and see if it freezes
Happy2Play 9802 Posted July 19, 2021 Posted July 19, 2021 We have seen most clients/devices have reported issues with excessive subtitles.
Carlo 4561 Posted July 19, 2021 Posted July 19, 2021 11 hours ago, RoyH said: I also have a second issue the Collections tab some of the Box set cases images are not populated I have the Auto Box Set installed. Boxsets Plugin is no longer used in 4.6+ versions of Emby Server. This is now built in with control settings at the library level. Try selecting a few collections without pics and then perform a meta-data update on them like shown in this pic Exit back to main menu and then go back into collections to update the graphics. Does this fix your issue?
rbjtech 5337 Posted July 19, 2021 Posted July 19, 2021 (edited) edit - commented on an old post - please delete .. Edited July 19, 2021 by rbjtech
RoyH 12 Posted July 19, 2021 Author Posted July 19, 2021 Did it to the 3 with arrow and it came back with 4 cover images each is that the way its done now instead on one image like the 3 to the left
Carlo 4561 Posted July 19, 2021 Posted July 19, 2021 If you edit your Collections "library" from Library menu in the web admin what settings do you have here?
Solution speechles 2062 Posted July 19, 2021 Solution Posted July 19, 2021 (edited) The problem with your subtitles is they are internal (embedded). The audio was not compatible. fmpeg has to direct stream copy and change the container. It is copying every single subtitle into the stream because these are embedded. Literally there are 31 subtitle streams available that ffmpeg is muxing in real time on-the-fly. You can instead have these supplied as external SRT and keep the same subtitles. SRT is just the external form of the internal subrip. Then ffmpeg only has to mux in the subtitle in use at the moment. This doesn't mean you cannot change subtitles with SRT. But SRT only has to contain the playing subtitle while all others remain external. For internal subrip all subtitles must be muxed. That is what was creating the burden is those 31 subtitle streams being muxed in. External SRT has huge benefits and this is just one of them. Edit: I would even go so far to say NEVER allow internal subrip to exist in your media and always extract them to external SRT as soon as you see them and delete the embedded subrip from the media afterwards. If all you use is Emby for media this is the best combination. Edited July 19, 2021 by speechles 2
Carlo 4561 Posted July 19, 2021 Posted July 19, 2021 11 minutes ago, RoyH said: OK what happens if you try searching for a new poster on one of these collections? Does it find a poster?
RoyH 12 Posted July 19, 2021 Author Posted July 19, 2021 12 minutes ago, cayars said: OK what happens if you try searching for a new poster on one of these collections? Does it find a poster? No it dont find anything
speechles 2062 Posted July 19, 2021 Posted July 19, 2021 Toggle that "All Languages" to ON. Sometimes Emby must be told anything is better than nothing. @Luke Why doesn't Emby default to "All Languages" when it finds nothing for the chosen? Too many possible API hit and blow that out? Some reason? Curious..
RoyH 12 Posted July 19, 2021 Author Posted July 19, 2021 19 minutes ago, speechles said: The problem with your subtitles is they are internal (embedded). The audio was not compatible. fmpeg has to direct stream copy and change the container. It is copying every single subtitle into the stream because these are embedded. Literally there are 31 subtitle streams available that ffmpeg is muxing in real time on-the-fly. You can instead have these supplied as external SRT and keep the same subtitles. SRT is just the external form of the internal subrip. Then ffmpeg only has to mux in the subtitle in use at the moment. This doesn't mean you cannot change subtitles with SRT. But SRT only has to contain the playing subtitle while all others remain external. For internal subrip all subtitles must be muxed. That is what was creating the burden is those 31 subtitle streams being muxed in. External SRT has huge benefits and this is just one of them. Edit: I would even go so far to say NEVER allow internal subrip to exist in your media and always extract them to external SRT as soon as you see them and delete the embedded subrip from the media afterwards. If all you use is Emby for media this is the best combination. I only speak English so don't need any of the other subs I took out all except for 1 sub and it worked without an issue. I also had another movie that shows pixelated from time to time and thought it was a bad copy turns out that it also had a lot of subs I muxed it and left 1 sub only and now it shows flawless multiple subs is really an issue will insure going forward I check all movies and remove unwanted subs. 1
Carlo 4561 Posted July 19, 2021 Posted July 19, 2021 3 hours ago, RoyH said: No it dont find anything What Collect was this?
RoyH 12 Posted July 19, 2021 Author Posted July 19, 2021 3 hours ago, cayars said: What Collect was this? Hunger Games and the Equalizer when you try to find a poster its no results but if you check them like you said at first and do meta-data update you get the 4mini posters
Happy2Play 9802 Posted July 19, 2021 Posted July 19, 2021 Can you post the server log for when you Searched for images for a Collection. But can only assume the migration from /data/collections to /metadata/collections did not go well.
RoyH 12 Posted July 20, 2021 Author Posted July 20, 2021 14 minutes ago, Happy2Play said: Can you post the server log for when you Searched for images for a Collection. But can only assume the migration from /data/collections to /metadata/collections did not go well. embyserver (2).txt
Carlo 4561 Posted July 20, 2021 Posted July 20, 2021 Do you get anything like this with individual search for images?
Happy2Play 9802 Posted July 20, 2021 Posted July 20, 2021 6 minutes ago, RoyH said: embyserver (2).txt 1.01 MB · 0 downloads I see Bad Boys Collection pulled a image from FanArt.tv. Do you have "Download images in advance" enabled on the library? If you enter a collection do the images populate? Download images in advance By default, most images are only downloaded when requested by an Emby app. Enable this option to download all images in advance, as new media is imported. This may cause significantly longer library scans.
