Jerequan 0 Posted June 14, 2021 Posted June 14, 2021 I have emby installed on my windows 10 gaming machine. It's always worked fine for the most part with little need to change much of anything. However, for the past year or so the internet connection on my pc drops when playing content anywhere around the house after an hour or so (sometimes sooner/sometimes longer). Although less frequent, this happens from time to time without playing content and when just browsing on the pc as well. I'm fairly certain it isn't a network issue because when these drops occur, the other devices on the network are still connected. Replaced an Ethernet cable, messed around with some windows adapter settings, and ran some virus and malware scans.. Still no luck. Is this an issue that could be verified or fixed by taking a look at the logs? I am lost and beginning to use the service less and less. I'm about ready to move the server to a new a device and see if the drops continue. Any other suggestions and help would be appreciated. I feel like there are probably a million threads about this same type of issue so I apologize if there is a better place for it.
Abobader 3485 Posted June 14, 2021 Posted June 14, 2021 Hello Jerequan, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9802 Posted June 14, 2021 Posted June 14, 2021 (edited) Almost sounds like a power management setting, but can say I have never experience this behavior but configured to be on 24/7. Edited June 14, 2021 by Happy2Play
Jerequan 0 Posted June 14, 2021 Author Posted June 14, 2021 (edited) Also, the issue never results in a reconnect. I have to manually go to the windows network troubleshooter where is does a "reset" of the adapter to re-stablish my internet connection. As for power management.. Couple weeks ago I went into "device manager" and then clicked network adapter dropdown, right clicked my adapter, then power management, and finally unticked "allow computer to turn off this device to save power." Still having this issue weeks later Edited June 14, 2021 by Jerequan
Carlo 4561 Posted June 21, 2021 Posted June 21, 2021 This almost sounds like failing hardware or a thermal issue to me. What I'd suggest is picking up a $10 to $12 USB3 to Ethernet dongle off Amazon and testing with that.
