unisoft 355 Posted June 12, 2021 Posted June 12, 2021 The older versions of emby had << and >> so you could navigate to next track or chapter in a music album or an audiobook. Audiobooks typically have lots of stories over many hours in one track. At the moment, its un-useable as no controls of going to next chapter or back. Can this be re-instated please instead of blindly copying what Spotify do? Thanks 1
Luke 42246 Posted June 14, 2021 Posted June 14, 2021 Hi, we haven't taken these away. I think you probably just only had one track in your play queue.
unisoft 355 Posted June 15, 2021 Author Posted June 15, 2021 12 hours ago, Luke said: Hi, we haven't taken these away. I think you probably just only had one track in your play queue. Yes that's exactly the problem. The Audiobooks downloaded are often ONE track, containing hours of audio. To go to next episode or chapter, the >> button is required which no longer exists. Each episode or chapter is usually chapter marked when authored.
Luke 42246 Posted June 15, 2021 Posted June 15, 2021 OK yes we can look at supporting chapters in audio files in future updates. thanks for the feedback. 2
