davedick 19 Posted June 12, 2021 Posted June 12, 2021 Emby keeps showing the same season and episode number even though past that episode. I tried finding the settings that determines when to mark a show completed, but I couldn't find it (at least thru the Android phone app)
Happy2Play 9802 Posted June 12, 2021 Posted June 12, 2021 Can you show an example, I don't know that app but every client should have a played indicator. Last resort you mark it as played in the web client.
davedick 19 Posted June 12, 2021 Author Posted June 12, 2021 (edited) Here is an example. Both Roku and Xbox one showed the same. Manually trying to mark played in either of these didn't work, but going to the web client and manually marking them as played, ot now shows what I would expect. Was the setting to determine the percentage watched get removed? I can't find it anywhere Edit. I found the percentage in the library section. Setup there looks correct. Edited June 12, 2021 by davedick
Happy2Play 9802 Posted June 12, 2021 Posted June 12, 2021 The combined Continue Watching/Next up is only capable of showing one episode from a Series so will be issues with partially watched items. You can always test reenabling Next Up Legacy to have these rows separate again via user Home Screen settings. 1
ebr 16309 Posted June 12, 2021 Posted June 12, 2021 Hi. Did you get an error message trying to mark the item watched?
Luke 42203 Posted June 12, 2021 Posted June 12, 2021 Hi, please attach the emby server log from when you tried to mark them as watched. thanks.
