justinrh 264 Posted June 10, 2021 Posted June 10, 2021 ? If scans can be a lengthy process it would be nice if the Dashboard shows scans in-progress.
Happy2Play 9802 Posted June 10, 2021 Posted June 10, 2021 (edited) 7 minutes ago, justinrh said: ? If scans can be a lengthy process it would be nice if the Dashboard shows scans in-progress. It does from when a full scan is done. Note if you are scanning a individual library, depending on the size of the library progress will be shown (done know if this applies to all clients though). This shows on each library during a full scan and if you do a individual library scan. Library size is relevant here though. Edited June 10, 2021 by Happy2Play 1
justinrh 264 Posted June 10, 2021 Author Posted June 10, 2021 Oh, didn't think to initiate it from the home screen. I was in the admin page. What about there? All I get is a pop-up saying it started.
Happy2Play 9802 Posted June 10, 2021 Posted June 10, 2021 Sorry I don't follow as I posted a image of what you see on the Dashboard. Now if you see something different then please post a screenshot.
justinrh 264 Posted June 10, 2021 Author Posted June 10, 2021 (edited) I guess the colors threw me off (I expected white like the default admin page colors). I go to admin -> Server -> Library select a sizable library to scan, select scan from the more menu immediately go to Dashboard - I don't see any 'running tasks' block, I don't see any indication a scan is happening Scanning a library scans all files and not just looks for deltas, correct? Edited June 10, 2021 by justinrh
Happy2Play 9802 Posted June 11, 2021 Posted June 11, 2021 Individual library scans will only show on the library per my images. Only full scans appear on the Dashboard. 1
Carlo 4561 Posted June 11, 2021 Posted June 11, 2021 Or you can kick off a full library scan from the Scheduled Task area as well. Regardless if you kick it off from the Library or Scheduled Task area (full library scan) you can see the status of completion on both the dashboard and schedule tasks page.
justinrh 264 Posted June 11, 2021 Author Posted June 11, 2021 14 hours ago, cayars said: Regardless if you kick it off from the Library or Scheduled Task area (full library scan) you can see the status of completion on both the dashboard and schedule tasks page @cayars now don't go confusing me again At first I thought you were saying from a library, but now I think you mean the Library page. This leads me to a logical bug in the admin area. This should be "Libraries", as it contains more than one library and it itself is not a library (as Emby understand libraries). 1
Happy2Play 9802 Posted June 11, 2021 Posted June 11, 2021 (edited) 5 minutes ago, justinrh said: This should be "Libraries", as it contains more than one library and it itself is not a library (as Emby understand libraries). But it could be Library if you only have one. But technically it is Library config/Library setup page. You can only add or configure 1 library at a time even though it will display all of them for you. Edited June 11, 2021 by Happy2Play
Carlo 4561 Posted June 11, 2021 Posted June 11, 2021 It probably should be plural as other most other menu options are. But I think we've all gotten so used to it being Library that we don't even notice it anymore.
justinrh 264 Posted June 11, 2021 Author Posted June 11, 2021 5 minutes ago, Happy2Play said: But it could be Library if you only have one. But technically it is Library config/Library setup page. You can only add or configure 1 library at a time even though it will display all of them for you. I still say there is an inconsistency... Apply your logic to these: Seriously, not wanting to make a big deal of this, but plural makes much more sense to me. Just sayin' for the record.
Happy2Play 9802 Posted June 11, 2021 Posted June 11, 2021 To me is it is subjective but I am not the dev.
Carlo 4561 Posted June 11, 2021 Posted June 11, 2021 2 minutes ago, justinrh said: Don't forget the first one SettingS. But then you could also say Network should become Networks as well since you can have multiple local networks or a local network and wan network as well.
Happy2Play 9802 Posted June 11, 2021 Posted June 11, 2021 And some are Proper names of plugins. So plural is irrelavent. 1
justinrh 264 Posted June 11, 2021 Author Posted June 11, 2021 Whew! I'm glad we have that thoroughly thrashed out now 1
