tnowakow 0 Posted June 10, 2021 Posted June 10, 2021 Hi everyone, I just got a new mecool KT1 Android TV device (The one with AV1 hardware decoding) and have been testing the features. Currently I have Emby set up to open files with MX Player Pro (That is able to use hardware decoding for AV1 files). Is there a roadmap to use hardware for AV1 files with the normal Emby built in player? Would love to have this as seamless as possible for the wife/kids. Thank you!
ebr 16338 Posted June 10, 2021 Posted June 10, 2021 Hi. Our player should already be taking advantage of the decoders available on the device. Have you tested it?
tnowakow 0 Posted June 10, 2021 Author Posted June 10, 2021 (edited) Yeah, I just tested it again and it says: Streaming Info Video Resolution: 1920x1080 Video Codec: AV1 (direct) Audio Codec: OPUS Audio Channels: 7.1 Bitrate: 3.14Mbps Max bitrate setting: 80 Mb/s Transcode Speed: 7577.00 fps Transcode Reason: Unsupported video EDIT: I went into my user and unchecked this: "Allow video playback that requires conversion without re-encoding" and it's playing now! but for OPUS it says (software decode) so i'm guessing OPUS isn't hardware enabled? Edited June 10, 2021 by tnowakow
ebr 16338 Posted June 10, 2021 Posted June 10, 2021 Can I please see the ffmpeg log that was generated before you changed your settings? Thanks.
tnowakow 0 Posted June 10, 2021 Author Posted June 10, 2021 Sure thing, I have attached it below ffmpeg-directstream_1.txt
