macv 2 Posted February 2, 2023 Author Posted February 2, 2023 (edited) 9 hours ago, Mnejing said: It takes less than a minute to deal with it yourself. Quite a braindead comment as entire software companies have succeeded on saving people less than a minute per transaction. Emby itself saved me 1 min from hooking up my laptop to the TV. Thanks for adding no value or info to the thread other than your obtuseness. Edited February 2, 2023 by macv 1 1
Mnejing 23 Posted February 2, 2023 Posted February 2, 2023 Look, you're complaining that breaking the law isn't easier for you. Grow up. Emby isn't being developed by some large-scale software company either. You can literally count the primary developers on a single hand. You've been told already that Emby expects files to be named a particular way. For the most part, even THAT is pretty loose. If you're unwilling to do even the smallest bit of work yourself, that's a YOU problem. 1
macv 2 Posted February 3, 2023 Author Posted February 3, 2023 (edited) Go make your irrelevant assumptions to your basement wall. Nobody cares. Edited February 3, 2023 by macv
strichmo 21 Posted February 3, 2023 Posted February 3, 2023 18 hours ago, Luke said: This should be improved with the upcoming 4.8 server release. Thanks. Thanks. It's great to see these improvements coming down the pipe! I saw Linus Techtips recently mentioned you in a video, and I get the feeling they're planning something more involved in the future for Emby! 1
Mnejing 23 Posted February 9, 2023 Posted February 9, 2023 On 2/3/2023 at 6:24 AM, macv said: Go make your irrelevant assumptions to your basement wall. Nobody cares. Ad hominems are going to get you nowhere. You're literally acting like a child.
seanbuff 1360 Posted February 9, 2023 Posted February 9, 2023 Let's keep it civil please folks. Devs have already commented that there will be improvements in this area. Thanks! 1
Luke 42289 Posted February 9, 2023 Posted February 9, 2023 Yes improvements have already been added for the upcoming 4.8 release. Both subtitles and subs folders will be supported, case-insensitive. 2
