KrakaClue 1 Posted June 7, 2021 Posted June 7, 2021 Hi everyone, I have a problem with the new feature "Tone Mapping" on my Windows server. I will try to give you all the information about my setup and tests: "Server" specs: Intel i5-8400 with iGPU UHD 630 and 16GB RAM Emby lifetime subscription All hardware and software transcoding is active (standard hardware transcoding work flawlessly with any clients). Tested Clients: Roku Streaming stick + 4k with no-HDR 1080p Monitor (emby client forced to maximum 8Mbps streaming) Macbook Pro 2020 with HDR Display - Emby on Chrome Browser (emby client forced to maximum 8Mbps streaming) Macbook Pro 2020 with HDR Display - Emby with Infuse Application --> This config guarantees direct HDR (emby client forced to maximum 8Mbps streaming) Tested Video: Spoiler Dimension: 19172MB Codec: HEVC Profile: Main 10 Level: 153 Resolution: 3840x1608 Aspect Ratio: 160:67 Interlaced: No Framerate: 23.976 Bitrate: 11,386 kbps Video Range: HDR10 Color Primaries: bt2020 Color Spacebt: 2020nc Color Transfer: smpte2084 Bit Depth: 10 bit Pixel Format: yuv420p10le Reference Frames: 1 Problem: ToneMapping does not work with clients who needs SDR streaming, all colours looks washed out. An example of video output in case 3: An example of video output in case 1 and 2: I took this video as reference because everyone know this scene, anyway I tested some other Movies with the same results. LOG file: >>>>>> User policy for ######## EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True >>>>>> Affected codecs Encoder QuickSync Intel(R) UHD Graphics 630 - D3D11 - H.264 (AVC) Adapter #0: 'Intel(R) UHD Graphics 630 - D3D11' Id:16018 (Driver: , Vendor: 32902, SDK Version: 1.27) Frame Sizes: 32x32...8192x8192 - Width Alignment: 16 - Height Alignment: 16 Color Formats: NV12, P010, QSV Profiles: Baseline Profile (Level 5.2), Main Profile (Level 5.2), High Profile (Level 5.2) Decoder QuickSync Intel(R) UHD Graphics 630 - D3D11 - H.265 (HEVC) Adapter #0: 'Intel(R) UHD Graphics 630 - D3D11' Id:16018 (Driver: , Vendor: 32902, SDK Version: 1.27) Frame Sizes: 16x16...16384x16384 - Width Alignment: 2 - Height Alignment: 2 Profiles: Main Profile (Level 6.2), Main 10 Profile (Level 6.2), Main Still Picture (Level 6.2) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Automatic Info Checking: 'QuickSync Intel(R) UHD Graphics 630 - D3D11 - H.264 (AVC)' Info Check successful - selecting 'QuickSync Intel(R) UHD Graphics 630 - D3D11 - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: hevc, Mode: Automatic Info Checking: 'QuickSync Intel(R) UHD Graphics 630 - D3D11 - H.265 (HEVC)' Info Check successful - selecting 'QuickSync Intel(R) UHD Graphics 630 - D3D11 - H.265 (HEVC)' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info QuickSync Intel(R) UHD Graphics 630 -... >> True True Hardware Codec Info VideoInput >> True True Same adapter Id (0), same hardware co... Info Scaling >> True True Info ToneMapping (when possible) >> True True Info VideoOutput >> True True Hardware encoder Info QuickSync Intel(R) UHD Graphics 630 -... >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info hevc_qsv >> QSV qsv p010 3840x1608 >> vpp_qsv Info vpp_qsv >> QSV qsv bgra 640x268 >> setparams Info setparams >> QSV qsv bgra 640x268 >> hwmap Info hwmap >> OPENCL opencl bgra 640x268 >> supertonemap_opencl Info supertonemap_opencl >> OPENCL opencl bgra 640x268 >> hwmap Info hwmap >> QSV qsv bgra 640x268 >> Can you help me with this problem?
Carlo 4561 Posted June 7, 2021 Posted June 7, 2021 Hi, right now only the server is tone mapping "smart" but the clients haven't been updated yet to take advantage of HDR->SDR. Once this happens you shouldn't have to force bitrates to get tone mapping on the client side. But for right now, let's see if we can figure this out for you. Can you show us the Media Info section for that movie? Bottom of the detail screen for the movie.
KrakaClue 1 Posted June 7, 2021 Author Posted June 7, 2021 47 minutes ago, cayars said: Hi, right now only the server is tone mapping "smart" but the clients haven't been updated yet to take advantage of HDR->SDR. Once this happens you shouldn't have to force bitrates to get tone mapping on the client side. But for right now, let's see if we can figure this out for you. Can you show us the Media Info section for that movie? Bottom of the detail screen for the movie. Hi Cayars, Thank you for the information, I did not know only the server was tone mapping ready so far. So my question is: are there any clients except Roku and WebBrowser that support HDR>>SDR nowadays? About your second question, the media info is: Dimension: 19172MB Codec: HEVC Profile: Main 10 Level: 153 Resolution: 3840x1608 Aspect Ratio: 160:67 Interlaced: No Framerate: 23.976 Bitrate: 11,386 kbps Video Range: HDR10 Color Primaries: bt2020 Color Spacebt: 2020nc Color Transfer: smpte2084 Bit Depth: 10 bit Pixel Format: yuv420p10le Reference Frames: 1 Best regards
Carlo 4561 Posted June 7, 2021 Posted June 7, 2021 Yes, I know the Shield TV & MiBox S can do HDR->SDR tone mapping. I'd have to check the Firestick 4K as I'm not sure on that one. Likely others as well but those are ones I have. But in order for those boxes to perform their magic they need to direct play the media. That's where a bit of smarts are needed in the clients which is coming. The clients need to know if the hardware can play the HDR natively or if the hardware can tone-map itself. Then knowing that it can force a tone-map transcode if needed for systems that can't handle it on their own. But of course it's not quite that simple as there are different HDR formats that complicate things as well as profile levels. With so many different combinations it's not so easy to do.
Luke 42203 Posted June 14, 2021 Posted June 14, 2021 Hi @KrakaClue, has this answered your questions?
KrakaClue 1 Posted June 14, 2021 Author Posted June 14, 2021 2 hours ago, Luke said: Hi @KrakaClue, has this answered your questions? Yes it is! I realised there is no solution nowadays to see HDR content on Roku (even with direct play) on non-HDR monitor. I hope to see some updates in the future
