sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 (edited) This should be mentioned in XBMC tread (http://forum.xbmc.org/showthread.php?tid=175430) as it works when XBMC metadata plugin is enabled I'll post there about it but I need to test some specifics (as XBMC doesn't modify movie/TV information once it's added to library with regular library updates) Edited October 10, 2013 by sfnetwork
AlwinHummels 134 Posted October 10, 2013 Posted October 10, 2013 (edited) Super I'll try it right now! Thanks for all your developing! This works great, now my genres are cleaned up nice Edited October 10, 2013 by AlwinHummels 2
Tharnax 49 Posted October 10, 2013 Posted October 10, 2013 Installed the plug-in and it is working as described. Well done Ebr!!
Cheesegeezer 3106 Posted October 10, 2013 Posted October 10, 2013 Love it Eric, I tried the alpha the other day and forgot to post back. This is a legendary and well needed addon, great job!!
Lee 212 Posted October 10, 2013 Posted October 10, 2013 oooh... Likey! I'll have to take a look at this... great idea
CBers 7557 Posted October 10, 2013 Posted October 10, 2013 I like the dude with the headphones on and remote in his top pocket 1
yardameus 221 Posted October 10, 2013 Posted October 10, 2013 Awesome... I'd "like" it, but I've reached my quota.
yardameus 221 Posted October 10, 2013 Posted October 10, 2013 Super I'll try it right now! Thanks for all your developing! This works great, now my genres are cleaned up nice Love your icons...
pagali 62 Posted October 10, 2013 Posted October 10, 2013 Very nice job! I've wished for something like this for a long time.
CloudVader 0 Posted October 10, 2013 Posted October 10, 2013 Fantastic. I've been looking for something like this for a while!
Logos302 86 Posted October 11, 2013 Posted October 11, 2013 Just what I needed .. Thank you, thank you, thank you....
Redshirt 1487 Posted October 11, 2013 Posted October 11, 2013 I like those icons too Alwin. Very nice.
ebr 16340 Posted October 11, 2013 Posted October 11, 2013 You guys can thank Christa (cwnashvegas) for the artwork.
AlwinHummels 134 Posted October 11, 2013 Posted October 11, 2013 Love your icons... Thanks I've ripped them from here so all complements belongs to the maker of those icons 1
aspdend 177 Posted October 11, 2013 Posted October 11, 2013 Excellent work - This will come in very handy indeed
DGMayor 90 Posted October 11, 2013 Posted October 11, 2013 Excellent plugin! Makes it a lot easier to deal with rogue genres when you don't want to go editing metadata (especially since it could possibly be reset/reloaded) at a later time.
porkbone 48 Posted October 11, 2013 Posted October 11, 2013 Excellent Job!! I was dreading doing this by hand. Thank You!
Crestj 68 Posted October 11, 2013 Posted October 11, 2013 (edited) Works great but I now see my music genres is completely all over the place! Some even seem to have Chinese symbols?!? Any ideas for sorting the music meta data out? Edited October 11, 2013 by Crestj
ebr 16340 Posted October 11, 2013 Posted October 11, 2013 Works great but I now see my music genres is completely all over the place! Some even seem to have Chinese symbols?!? Any ideas for sorting the music meta data out? Well, I have no idea what you mean since you said it "worked great" but then said it didn't. Please provide some information about what you did and what happened that you felt was a problem. How to report a problem
