bob58523 0 Posted June 7, 2021 Posted June 7, 2021 Hello, I was running ubuntu server for over a year and never had a problem with connections, internal or external. After last emby update several months ago I could no longer access over internet with https or emby connect on any device, internal lan was fine. So, I installed debian 10 and I am having the same problem with the newest version of emby server. I can connect fine internally, but not over internet. Could anyone help? I have been working at this on and off for several months and it is very frustrating. Thank you, Bob
mastrmind11 722 Posted June 7, 2021 Posted June 7, 2021 are your proper ports forwarded? what have you checked/tried?
bob58523 0 Posted June 7, 2021 Author Posted June 7, 2021 I have forwarded 8096 and 8092... I guess what I can't figure out is why it worked for almost a year and then stopped.
bob58523 0 Posted June 8, 2021 Author Posted June 8, 2021 I did try the check port page in connection help and it says cannot see service... but the ports are forwarded correctly as emby-server
bob58523 0 Posted June 8, 2021 Author Posted June 8, 2021 I am using the ip address that emby shows in the control panel
Luke 42246 Posted June 8, 2021 Posted June 8, 2021 Hi there @bob58523, I would suggest checking out our Connection Troubleshooter: https://support.emby.media/support/solutions/articles/44001849007-connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
bob58523 0 Posted June 8, 2021 Author Posted June 8, 2021 Hi, As I mentioned when I use the check port utility it cannot access port. I do have a ddns server from my provider.. but I have no idea how to set up bind (I am using debian 10). I have looked at tutorials but they really don't help... I've not used Linux command line enough. I still can't figure out why it worked for a year, and suddenly quit working when all I did was update emby and did Linux updates. I choose emby because it worked right away, I do have emby premiere, and really don't want to try something else, but I may have too if I can't get this working. I did everything in the tutorial that was mentioned above, but it did not work.
Luke 42246 Posted June 9, 2021 Posted June 9, 2021 17 hours ago, bob58523 said: Hi, As I mentioned when I use the check port utility it cannot access port. I do have a ddns server from my provider.. but I have no idea how to set up bind (I am using debian 10). I have looked at tutorials but they really don't help... I've not used Linux command line enough. I still can't figure out why it worked for a year, and suddenly quit working when all I did was update emby and did Linux updates. I choose emby because it worked right away, I do have emby premiere, and really don't want to try something else, but I may have too if I can't get this working. I did everything in the tutorial that was mentioned above, but it did not work. Hi, @bob58523 which steps in the help article succeeded and which ones did not?
