ebr 16336 Posted July 23, 2021 Posted July 23, 2021 Thanks for the log. I think I can investigate now. 1
horstepipe 423 Posted August 23, 2021 Author Posted August 23, 2021 (edited) Thanks for adding sort by channel numbers if channels are sorted into tags, it works without issues! But the „tag selection“ icon still disappears/reappears in v39. Unfortunately I‘m still unable to see a pattern here. Any idea how to track that down? Edited August 23, 2021 by horstepipe
ebr 16336 Posted August 23, 2021 Posted August 23, 2021 3 hours ago, horstepipe said: But the „tag selection“ icon still disappears/reappears in v39. Unfortunately I‘m still unable to see a pattern here I cannot reproduce this. The next time it happens, please post a screen shot. Thanks.
horstepipe 423 Posted August 24, 2021 Author Posted August 24, 2021 it is very easy to see that behavior here. I open Emby and enter the live tv node. i'm seeing the button now. I switch to channels, go back to tv guide and the button disappeared. I sent a log of this as 18.07 (Germany)
ebr 16336 Posted August 24, 2021 Posted August 24, 2021 50 minutes ago, horstepipe said: I open Emby and enter the live tv node. i'm seeing the button now. I switch to channels, go back to tv guide and the button disappeared With that procedure I am able to reproduce. Thanks. 1
horstepipe 423 Posted October 12, 2021 Author Posted October 12, 2021 So it is way better, but I still run into disappearing of the button quite often, mostly on the OSD now. Would another inapp log help after the button disappears?
ebr 16336 Posted October 12, 2021 Posted October 12, 2021 6 hours ago, horstepipe said: So it is way better, but I still run into disappearing of the button quite often, mostly on the OSD now. Would another inapp log help after the button disappears? An exact set of steps to reproduce is probably better. Thanks.
horstepipe 423 Posted October 14, 2021 Author Posted October 14, 2021 So let’s see if you can reproduce: - Enable tag filtering in live tv menu and start a channel - press menu button and the tag filter (red) button) - choose a tag and exit the osd - press menu again and the button disappears
ebr 16336 Posted October 14, 2021 Posted October 14, 2021 So this is with the on-screen guide as opposed to the view on its own?
