MAX92 93 Posted June 4, 2021 Posted June 4, 2021 Today, it is not possible to accelerate video if bitsreaming compressed audio. (DTS, DD) VLC can do on all type audio. I hope it can be the same on Android TV.
ebr 16339 Posted June 4, 2021 Posted June 4, 2021 Hi. VLC is able to adjust speed when bitstreaming audio? Are you sure they aren't locally decoding it to PCM and sending that out? I don't see how you could adjust the speed of a compressed audio stream but maybe they have some sort of black magic...
MAX92 93 Posted June 4, 2021 Author Posted June 4, 2021 I confirm that VLC is able to adjust speed of all video. Just to be sure, I can't accelerate with EMBY Android TV this video but no problem with VLC
ebr 16339 Posted June 4, 2021 Posted June 4, 2021 Right, but is VLC actually sending a bitstream to your AVR or is it decoding the audio and sending PCM? Our app can do the latter as well, if you select the option to "downmix to stereo".
MAX92 93 Posted June 4, 2021 Author Posted June 4, 2021 (edited) VLC decode, I dont' have DD ou DTS when I accelarate. ""downmix to stereo" Where is this option to try ? Edited June 4, 2021 by MAX92
MAX92 93 Posted June 4, 2021 Author Posted June 4, 2021 I found the downmix to stereo. It's working. As it can be great because I put auto is the option change to downmix to stereo when it is necessary. (when you want adjust speed for example.
MAX92 93 Posted July 6, 2021 Author Posted July 6, 2021 @ebrDo you think it can be possible to EMBY to always show "change speed" and modify the downmix to stereo when it will be necessairy ?
ebr 16339 Posted July 6, 2021 Posted July 6, 2021 1 hour ago, MAX92 said: @ebrDo you think it can be possible to EMBY to always show "change speed" and modify the downmix to stereo when it will be necessairy ? Possibly...
