GrimReaper 4902 Posted June 3, 2021 Posted June 3, 2021 As discussed here: Multiple webhooks sent on Playback finished (and some other stuff) - Developer API - Emby Community Double webhook (Stop/Scrobble) is being sent upon Playback finished in AndroidTV App: Kindly adjust above so that only Scrobble is sent upon finish. Thanks
ebr 16338 Posted June 3, 2021 Posted June 3, 2021 Hi. The app has no knowledge of what a "scrobble" is so this must be something in the webhooks plug-in...
GrimReaper 4902 Posted June 3, 2021 Author Posted June 3, 2021 (edited) 28 minutes ago, ebr said: Hi. The app has no knowledge of what a "scrobble" is so this must be something in the webhooks plug-in... Hi, @ebr. As visible here in Web App playback: Triple webhook sent on Playback finished - Web App - Emby Community Scrobble is sent on finish, in addition to Pause and Stop. If needed, I will obtain logs for AndroidTV as well. Edit: To clarify, @Luke stated in original topic Multiple webhooks sent on Playback finished (and some other stuff) - Developer API - Emby Community that it should be reported to each individual app as server is only relaying events. Edited June 3, 2021 by GrimReaper76
GrimReaper 4902 Posted June 3, 2021 Author Posted June 3, 2021 20 minutes ago, speechles said: Are you using the Trakt plugin? Nope, don't even have it installed.
