GrimReaper 4896 Posted June 3, 2021 Posted June 3, 2021 As discussed here: Multiple webhooks sent on Playback finished (and some other stuff) - Developer API - Emby Community Triple webhook (Pause/Stop/Scrobble) is being sent upon Playback finished in Emby Web: Kindly adjust above so that only Scrobble is sent upon finish. Thanks
GrimReaper 4896 Posted June 4, 2021 Author Posted June 4, 2021 (edited) 2 hours ago, Luke said: Did you press stop, or did it run to the end? It ran to the end, if Stop is pressed before the end only Stop is sent, and that works OK, same as Pause and Resume do work correctly. Edit: And it happens both on Movies and TV Shows, in latter case irrespective whether Play next episode automatically is enabled or disabled. Edited June 4, 2021 by GrimReaper76
