Luke 42240 Posted June 6, 2021 Posted June 6, 2021 In your first post you said you could only play a video for two seconds, right? I thought that was the issue?
DragoMag 4 Posted June 6, 2021 Author Posted June 6, 2021 Yes that's it, I always have the same problem and on all the films...
Luke 42240 Posted June 6, 2021 Posted June 6, 2021 6 minutes ago, DragoMag said: Yes that's it, I always have the same problem and on all the films... Can you please try to play something again, and then attach the emby server log? Thanks.
DragoMag 4 Posted June 6, 2021 Author Posted June 6, 2021 Can I delete all the logs? And play again ?
Carlo 4561 Posted June 6, 2021 Posted June 6, 2021 7 minutes ago, DragoMag said: Can I delete all the logs? And play again? Yes that's fine but you may need to shut down Emby to delete them all.
DragoMag 4 Posted June 7, 2021 Author Posted June 7, 2021 (edited) Hello, So I stopped the server, deleted all the logs, restarted, the movie froze only once during my test, and always in the same place but afterwards, everything was fine. I put you all the files that are in the logs. Thank you very much, hardware_detection-63758657720.txt embyserver (1).txt Edited June 7, 2021 by DragoMag
Luke 42240 Posted June 8, 2021 Posted June 8, 2021 On 6/7/2021 at 4:21 AM, DragoMag said: Hello, So I stopped the server, deleted all the logs, restarted, the movie froze only once during my test, and always in the same place but afterwards, everything was fine. I put you all the files that are in the logs. Thank you very much, hardware_detection-63758657720.txt 127.98 kB · 1 download embyserver (1).txt 168.27 kB · 5 downloads Can you attach the corresponding ffmpeg log as well? Thanks !
thymon 11 Posted June 24, 2021 Posted June 24, 2021 1 seul core ? c'est possible ça ? ca parait trop peu pour emby
Carlo 4561 Posted June 25, 2021 Posted June 25, 2021 21 hours ago, thymon said: 1 single core? is that possible? it seems too little for emby Maybe running some type of VM it would be.
