adoteq 0 Posted June 3, 2021 Posted June 3, 2021 Hi, I would like to have support for direct stream for (AIFF, FLAC,WAV) to pcm. On plex this works for aiff on android, chromecast and desktop applications. Chromecast in particular needs pcm codec, and for android / desktop applications? They may even play aiff without conversion. Awaiting your response, Joannes Wyckmans
adoteq 0 Posted June 4, 2021 Author Posted June 4, 2021 It does transcodes to aac 384 kbps, but I know from Plex that android mobile (and android tv) support all PCM formats natively, or using transcodes to PCM format(unpacking PCM from container) PCM format examples: WAV, AIFF, ...
adoteq 0 Posted June 6, 2021 Author Posted June 6, 2021 See this thread: https://forums.plex.tv/t/please-update-xmls-in-profiles-with-following/714137/4
Luke 42246 Posted June 14, 2021 Posted June 14, 2021 Just for testing purposes, try playing these with our android and chromecast apps with user transcoding permissions restricted. The result of that will tell us how easily this could be supported or not.
adoteq 0 Posted October 18, 2021 Author Posted October 18, 2021 (edited) Hi. I would like to add to this thread that currently the android tv app is properly direct playing aiff container (2.0.48g registered) Thank you for that. Would like IT for android mobile aswell, but that might be on the way? Edited October 18, 2021 by adoteq
adoteq 0 Posted October 19, 2021 Author Posted October 19, 2021 Hi. I would like to add to this thread that currently the android tv app is properly direct playing aiff container Thank you for that. Would like IT for android mobile aswell, but that might be on the way? I found that the android beta app seems to correctly playback aiff. Thanks already, I cannot wait for IT to get out of beta.
adoteq 0 Posted October 19, 2021 Author Posted October 19, 2021 IT doesn't state it is directplaying though. It States transcodes to aac 384kbps. Maybe the server Needs to be beta aswell?
Luke 42246 Posted October 19, 2021 Posted October 19, 2021 14 minutes ago, adoteq said: IT doesn't state it is directplaying though. It States transcodes to aac 384kbps. Maybe the server Needs to be beta aswell? When playing with what app?
adoteq 0 Posted October 19, 2021 Author Posted October 19, 2021 (edited) Emby for android 3.2.19. I opted in for beta because of the regular app stating transcodes. My ears seem to hear uncompressed. but I AM not totally sure. So beta app seems to be uncompressed, regular app seems to be compressed, which only regular app seems to do transcoding. Both give transcodes in server dashboard Edited October 19, 2021 by adoteq
adoteq 0 Posted October 19, 2021 Author Posted October 19, 2021 It might, I need to test further. But it states transcoding, so that might be wrong. The android TV app sounds satisfactory, like the ios app does.
adoteq 0 Posted October 19, 2021 Author Posted October 19, 2021 Yes, I think IT doesn't transcode. 99% sure. So only the message Needs to be changed in the dashboard I think.
adoteq 0 Posted October 19, 2021 Author Posted October 19, 2021 This only applies to android mobile beta app
adoteq 0 Posted October 21, 2021 Author Posted October 21, 2021 (edited) 3.2.20 beta sounds even better. However, technically the 3.2.19 is better with most songs. 3.2.20 is more balanced overall, more depth Edited October 21, 2021 by adoteq
adoteq 0 Posted October 21, 2021 Author Posted October 21, 2021 (edited) 3.2.20 beta sounds even better Dont take into account what I mentioned earlier. 3.2.20 sounds the best Edited October 21, 2021 by adoteq
Luke 42246 Posted October 21, 2021 Posted October 21, 2021 They really should be the same but thanks for the update.
adoteq 0 Posted October 26, 2021 Author Posted October 26, 2021 (edited) Are you sure you don't transcode? It seems I get transcode. I have done some testing, but the quality seems to degrade. Might be my tv transcoding to the optical interface, but, Just asking to be sure. It sounds more like flac then PCM Edited October 26, 2021 by adoteq
Luke 42246 Posted October 26, 2021 Posted October 26, 2021 11 minutes ago, adoteq said: Are you sure you don't transcode? It seems I get transcode. I have done some testing, but the quality seems to degrade. Might be my tv transcoding to the optical interface, but, Just asking to be sure. It sounds more like flac then PCM We'd have to look at an example in detail: Thanks !
adoteq 0 Posted June 29, 2022 Author Posted June 29, 2022 @Luke Hi. I can get AIFF playback on my phone using android mobile app, but it refuses to playback aiff in 24 bit. Can you please elaborate current support any further? 16bit 44.1khz aiff plays back fine.
Luke 42246 Posted June 29, 2022 Posted June 29, 2022 10 hours ago, adoteq said: @Luke Hi. I can get AIFF playback on my phone using android mobile app, but it refuses to playback aiff in 24 bit. Can you please elaborate current support any further? 16bit 44.1khz aiff plays back fine. Hi, what happens when you try?
adoteq 0 Posted June 29, 2022 Author Posted June 29, 2022 @Luke It says it cannot play. (AIFF 16BIT does direct play, Just as 16&24bit FLAC does). In VLC media player it also Plays 24bit AIFF locally. But using emby app aiff only Plays at 16bit. I currently haven't installed emby atm. I Will try when there is a fix. I have android 11 on Oppo Reno. Oppo is a Chinese hifi brand that started selling smartphones a while back. If I remember correctly they also specifically stated AIFF support among other containers. I hope this helps.
Luke 42246 Posted June 29, 2022 Posted June 29, 2022 1 minute ago, adoteq said: No compatibel streams to be precise Can you please look at my previous response from October and provide all of that requested information? Thanks.
