Lenders57 21 Posted July 5, 2021 Author Posted July 5, 2021 (edited) I got this issue today and I found something very very strange in the android log... You can see at the firt line: "request to https://my-tld:8920" Why the port is added to my domain ? I used nginx and I have a reverse proxy. If I removed the port, I get a 200... Mon Jul 05 17:04:38 GMT+02:00 2021 Error sending request to https://<<<my-tld>>>[:8920 ???? what is this ? ]/emby/system/info/public?format=json: failed to connect to <<<my-tld>>>/<<<<my-server-ip>>> (port 8920) from /10.19.76.52 (port 48472) after 10000ms java.net.SocketTimeoutException libcore.io.IoBridge.connectErrno(IoBridge.java:191) libcore.io.IoBridge.connect(IoBridge.java:135) java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:142) java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:390) java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:230) java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:212) java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436) java.net.Socket.connect(Socket.java:621) okhttp3.internal.platform.AndroidPlatform.connectSocket(AndroidPlatform.kt:56) okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.kt:268) okhttp3.internal.connection.RealConnection.connect(RealConnection.kt:176) okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.kt:236) okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.kt:109) okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.kt:77) okhttp3.internal.connection.Transmitter.newExchange$okhttp(Transmitter.kt:162) okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:35) okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:112) okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:87) okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:82) okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:112) okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:87) okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:84) okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:112) okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:71) okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:112) okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:87) okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.kt:184) okhttp3.RealCall$AsyncCall.run(RealCall.kt:136) java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641) java.lang.Thread.run(Thread.java:919) Edit: I juste unchecked the button "allowed remote connection" in the dashboard, I can access to my server externally, I will try again if I got this issue Edited July 5, 2021 by Lenders57
Lenders57 21 Posted July 7, 2021 Author Posted July 7, 2021 I already have the issue even after change the settings and reboot the server; any idea @Luke ?
Luke 42243 Posted July 7, 2021 Posted July 7, 2021 Make sure the public facing ports are configured correctly in Emby Server and that the remote address displayed on your server dashboard is correct.
Lenders57 21 Posted July 7, 2021 Author Posted July 7, 2021 1 minute ago, Luke said: Make sure the public facing ports are configured correctly in Emby Server and that the remote address displayed on your server dashboard is correct. I disabled the remote address, I use a reverse proxy. So I don't understand where this url come from
Luke 42243 Posted July 8, 2021 Posted July 8, 2021 12 hours ago, Lenders57 said: I disabled the remote address, I use a reverse proxy. So I don't understand where this url come from You're still connecting remotely, so please look into what I suggested. Thanks.
