Luke 42255 Posted January 7, 2022 Posted January 7, 2022 20 hours ago, Bazzu85 said: Hi @Luke I'm here again to post a trakt plugin bug.. Starting from this episode with half progression: and checking that the progress is synced on trakt with Trakt.tv Playback Progress Manager (https://sharkykh.github.io/tppm/) Running the trakt import from scheduled tasks: the progress is resetted on emby side: NB: the problem is only for some episodes in next up section.. from previous months tests occurs with epidode without IMDB ID do you need some logs? Yes please, thanks.
Bazzu85 22 Posted January 9, 2022 Author Posted January 9, 2022 On 07/01/2022 at 20:35, Luke said: Yes please, thanks. I PMed you the logs..
Bazzu85 22 Posted January 12, 2022 Author Posted January 12, 2022 On 07/01/2022 at 20:35, Luke said: Yes please, thanks. Hi, any feedback about the provided logs? thx
Luke 42255 Posted January 14, 2022 Posted January 14, 2022 Does the episode have any external id's set in the metadata editor?
Bazzu85 22 Posted January 18, 2022 Author Posted January 18, 2022 On 14/01/2022 at 20:01, Luke said: Does the episode have any external id's set in the metadata editor? Here's the metadata screen:
Luke 42255 Posted January 19, 2022 Posted January 19, 2022 23 hours ago, Bazzu85 said: Here's the metadata screen: Wasn't Trakt starting to switch shows over to Tmdb?
Bazzu85 22 Posted January 19, 2022 Author Posted January 19, 2022 5 hours ago, Luke said: Wasn't Trakt starting to switch shows over to Tmdb? Yes.. You're saying that the problem is the missing tmdb id?
Luke 42255 Posted January 24, 2022 Posted January 24, 2022 On 1/19/2022 at 5:06 PM, Bazzu85 said: Yes.. You're saying that the problem is the missing tmdb id? Is that a common factor among these episodes?
Bazzu85 22 Posted July 2, 2022 Author Posted July 2, 2022 Hi running emby server 4.7.5 and trakt plugin 3.5.8. When watching something the progress is not saved directly to trakt. This cause that when during the import playstates scheduled task (at 3am every night) the situation return before the watch. Here's an example.. I finished watching one piece 18x759 and started the next. On trakt the progress remain as this: The last time I checked the situation emby updated the progress correctly. I don't know if is a 4.7.5 problem but last year after the 4.6.4 the problem was fixed..
Bazzu85 22 Posted July 2, 2022 Author Posted July 2, 2022 (edited) Hi running emby server 4.7.5 and trakt plugin 3.5.8. When watching something the progress is not saved directly to trakt. This cause that when during the import playstates scheduled task (at 3am every night) the situation return before the watch. Here's an example.. I finished watching one piece 18x13 and started the next. On trakt the progress remain as this (probably updated when there wasn't the problem): The last time I checked the situation emby updated the progress correctly. I don't know if is a 4.7.5 problem but last year after the 4.6.4 the problem was fixed.. Edit: the problem happens on one piece and not in other regular shows (check How I met your father right now). Maybe is related to the trakt numbering? Has you see is reported as 18x759 but on tvdb is a more realistic one (18x13). 759 is the absolute number. additional infos. The episode has the external links in metadata. Running sync task before import task doesn't resolve the problem. The progress and played flag are not updated Edited July 3, 2022 by Bazzu85
Bazzu85 22 Posted July 2, 2022 Author Posted July 2, 2022 (edited) Additional infos: I'm at pc now and I can paste logs and give more detailed infos. first I refreshed all metadata and the one piece episodes I'm refering here: Have the trakt button working on episode page taking to the correct trakt page Have the correct external ids (screenshot) Tried to play from the beginning One Piece S18E14 (absolute number 760) and these are the logs: embyserver play one piece s18e14 from the beginning.txt I see this part that can be the problem: 2022-07-02 11:55:47.414 Info SessionManager: Playback start reported by app Emby Web 4.7.5.0 playing Distruzione della capitale - I pirati di Sopracciglio di Paglia arrivano sulla terra!. Started at 0 ms 2022-07-02 11:55:47.418 Info Trakt: Playback Started 2022-07-02 11:55:47.418 Debug Trakt: 12c85f9f5a21413e91e0347775113760 appears to be monitoring I:\00 - Online Media\Anime\One Piece (1999)\Stagione 18 [720p x264] [JAPANESE]\One Piece (1999) - S18E14 - 760 - Distruzione della capitale - I pirati di Sopracciglio di Paglia arrivano s... [WEBDL 720p x264] [JAPANESE].mkv 2022-07-02 11:55:47.418 Debug Trakt: Send episode status update 2022-07-02 11:55:47.418 Info Server: http/1.1 Response 204 to ::1. Time: 8ms. http://localhost:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0&reqformat=json 2022-07-02 11:55:47.419 Info HttpClient: POST https://api.trakt.tv/scrobble/start 2022-07-02 11:55:47.528 Info Server: http/1.1 POST http://localhost:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 11:55:47.528 Debug SessionManager: OnPlaybackProgress TimeUpdate cbf859c5e3604d0f8e180b81e9a54711 2022-07-02 11:55:47.529 Info Server: http/1.1 Response 204 to ::1. Time: 1ms. http://localhost:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0&reqformat=json 2022-07-02 11:55:47.578 Error Trakt: Exception handled sending status update *** Error Report *** Version: 4.7.5.0 Command line: C:\Users\elbaz\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19044 Framework: .NET 6.0.5 OS/Process: x64/x64 Runtime: C:/Users/elbaz/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\elbaz\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\elbaz\AppData\Roaming\Emby-Server\system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendEpisodeStatusUpdateAsync(Episode episode, MediaStatus status, TraktUser traktUser, Single progressPercent, CancellationToken cancellationToken) at Trakt.ServerMediator.KernelPlaybackStart(Object sender, PlaybackProgressEventArgs e) Source: Emby.Server.Implementations TargetSite: Void MoveNext() when stopping the log have errors too: 2022-07-02 12:07:49.699 Info Trakt: Playback Stopped 2022-07-02 12:07:49.699 Info Server: http/1.1 Response 204 to ::1. Time: 2ms. http://localhost:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0&reqformat=json 2022-07-02 12:07:49.699 Info Trakt: Item Not fully played. Tell trakt.tv we are no longer watching but don't scrobble 2022-07-02 12:07:49.699 Info HttpClient: POST https://api.trakt.tv/scrobble/pause 2022-07-02 12:07:49.766 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Resume?Recursive=true&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&MediaTypes=Video&Limit=12&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.766 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=767bffe4f11c93ef34b805451a696a4e&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.766 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=0c41907140d802bb58430fed7e2cd79e&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.766 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=bdf38141c3a366eb1a2a8240d2e65e68&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.767 Debug SqliteItemRepository: GetInternalId from 0c419071-40d8-02bb-5843-0fed7e2cd79e 2022-07-02 12:07:49.769 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=9d7ad6afe9afa2dab1a2f6e00ad28fa6&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.848 Debug SqliteItemRepository: GetInternalId from 767bffe4-f11c-93ef-34b8-05451a696a4e 2022-07-02 12:07:49.878 Info Server: http/1.1 Response 206 to ::1. Time: 31201ms. http://localhost:8096/emby/videos/464814/stream.mkv?DeviceId=44d989c3-e15b-4676-8c9e-cbfd42664808&MediaSourceId=8cf00b245b7dbca63d81ffe5fa863261&Static=true&PlaySessionId=267437aa526e48f7a884ac5b0eb206cb 2022-07-02 12:07:49.882 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:50.146 Error Trakt: Error sending scrobble *** Error Report *** Version: 4.7.5.0 Command line: C:\Users\elbaz\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19044 Framework: .NET 6.0.5 OS/Process: x64/x64 Runtime: C:/Users/elbaz/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\elbaz\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\elbaz\AppData\Roaming\Emby-Server\system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendEpisodeStatusUpdateAsync(Episode episode, MediaStatus status, TraktUser traktUser, Single progressPercent, CancellationToken cancellationToken) at Trakt.ServerMediator.KernelPlaybackStopped(Object sender, PlaybackStopEventArgs e) Source: Emby.Server.Implementations TargetSite: Void MoveNext() for another episode I have only: 2022-07-02 12:02:11.359 Info Trakt: Playback Started 2022-07-02 12:02:11.359 Debug Trakt: 12c85f9f5a21413e91e0347775113760 appears to be monitoring H:\Serie Tv\How I Met Your Father (2022)\Stagione 01 [720p HEVC] [ITA+ENG]\How I Met Your Father (2022) - S01E09 - Jay Street [WEBDL 720p HEVC] [ITA+ENG].mkv 2022-07-02 12:02:11.359 Debug Trakt: Send episode status update 2022-07-02 12:02:11.359 Info Server: http/1.1 Response 204 to ::1. Time: 23ms. http://localhost:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0&reqformat=json 2022-07-02 12:02:11.359 Info HttpClient: POST https://api.trakt.tv/scrobble/start and when stopping: 2022-07-02 12:05:25.537 Info Trakt: Playback Stopped 2022-07-02 12:05:25.537 Info Trakt: Item Not fully played. Tell trakt.tv we are no longer watching but don't scrobble 2022-07-02 12:05:25.537 Info HttpClient: POST https://api.trakt.tv/scrobble/pause and the progress is correctly updated.. Edited July 2, 2022 by Bazzu85 additional infos
Bazzu85 22 Posted July 3, 2022 Author Posted July 3, 2022 (edited) @Luke any thoughts about the error? The last time I watched an episode of one piece and that was tracked as played on trakt was 18x12 on 25 of june. After that date can something have broke the sync? Here's my updates Edited July 3, 2022 by Bazzu85
Luke 42255 Posted July 5, 2022 Posted July 5, 2022 Does the episode have any external id's set in the metadata editor?
Bazzu85 22 Posted July 5, 2022 Author Posted July 5, 2022 3 hours ago, Luke said: Does the episode have any external id's set in the metadata editor? Yes. Here's And the link are the correct one's
Bazzu85 22 Posted July 5, 2022 Author Posted July 5, 2022 (edited) 20 minutes ago, Luke said: Are the external ids at the series level correct? yes, here's: Edited July 5, 2022 by Bazzu85
Bazzu85 22 Posted July 7, 2022 Author Posted July 7, 2022 @Luke I found something strange on trakt site Here's a one piece episode: https://trakt.tv/shows/one-piece/seasons/18/episodes/760 And here's a Demon Slayer one (this show works) https://trakt.tv/shows/demon-slayer-kimetsu-no-yaiba/seasons/3/episodes/1 The episode numbering for One Piece on the link itself is a bit strange. what do you think? Maybe the plugin need to be improved to build the correct URL in some scenarios? This is an article talking about Anime management https://support.trakt.tv/support/solutions/articles/70000427613-all-about-anime But this numbering method using the absolute numbers is not standard..
rodainas 191 Posted July 7, 2022 Posted July 7, 2022 (edited) 32 minutes ago, Bazzu85 said: @Luke I found something strange on trakt site Here's a one piece episode: https://trakt.tv/shows/one-piece/seasons/18/episodes/760 And here's a Demon Slayer one (this show works) https://trakt.tv/shows/demon-slayer-kimetsu-no-yaiba/seasons/3/episodes/1 The episode numbering for One Piece on the link itself is a bit strange. what do you think? Maybe the plugin need to be improved to build the correct URL in some scenarios? This is an article talking about Anime management https://support.trakt.tv/support/solutions/articles/70000427613-all-about-anime But this numbering method using the absolute numbers is not standard.. The numbering method corresponds to what tmdb uses. For One Piece they basically mix seasons with the episode absolute ordering, the result multiple seasons but with one sequence of episodes. The other thing for that episode is that the id link for tmdb doesnt work is outdated. https://www.themoviedb.org/tv/37854/seasons Edited July 7, 2022 by rodainas Append
Bazzu85 22 Posted July 7, 2022 Author Posted July 7, 2022 59 minutes ago, rodainas said: The numbering method corresponds to what tmdb uses. For One Piece they basically mix seasons with the episode absolute ordering, the result multiple seasons but with one sequence of episodes. The other thing for that episode is that the id link for tmdb doesnt work is outdated. https://www.themoviedb.org/tv/37854/seasons If you're refering to the trakt page the link is correcttly pointing to episode 760: that takes to this page: The problem on trakt scrobbler btw is the not found exception when start playing: 2022-07-02 11:55:47.414 Info SessionManager: Playback start reported by app Emby Web 4.7.5.0 playing Distruzione della capitale - I pirati di Sopracciglio di Paglia arrivano sulla terra!. Started at 0 ms 2022-07-02 11:55:47.418 Info Trakt: Playback Started 2022-07-02 11:55:47.418 Debug Trakt: 12c85f9f5a21413e91e0347775113760 appears to be monitoring I:\00 - Online Media\Anime\One Piece (1999)\Stagione 18 [720p x264] [JAPANESE]\One Piece (1999) - S18E14 - 760 - Distruzione della capitale - I pirati di Sopracciglio di Paglia arrivano s... [WEBDL 720p x264] [JAPANESE].mkv 2022-07-02 11:55:47.418 Debug Trakt: Send episode status update 2022-07-02 11:55:47.418 Info Server: http/1.1 Response 204 to ::1. Time: 8ms. http://localhost:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0&reqformat=json 2022-07-02 11:55:47.419 Info HttpClient: POST https://api.trakt.tv/scrobble/start 2022-07-02 11:55:47.528 Info Server: http/1.1 POST http://localhost:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 11:55:47.528 Debug SessionManager: OnPlaybackProgress TimeUpdate cbf859c5e3604d0f8e180b81e9a54711 2022-07-02 11:55:47.529 Info Server: http/1.1 Response 204 to ::1. Time: 1ms. http://localhost:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0&reqformat=json 2022-07-02 11:55:47.578 Error Trakt: Exception handled sending status update *** Error Report *** Version: 4.7.5.0 Command line: C:\Users\elbaz\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19044 Framework: .NET 6.0.5 OS/Process: x64/x64 Runtime: C:/Users/elbaz/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\elbaz\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\elbaz\AppData\Roaming\Emby-Server\system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendEpisodeStatusUpdateAsync(Episode episode, MediaStatus status, TraktUser traktUser, Single progressPercent, CancellationToken cancellationToken) at Trakt.ServerMediator.KernelPlaybackStart(Object sender, PlaybackProgressEventArgs e) Source: Emby.Server.Implementations TargetSite: Void MoveNext() and when stopping: 2022-07-02 12:07:49.699 Info Trakt: Playback Stopped 2022-07-02 12:07:49.699 Info Server: http/1.1 Response 204 to ::1. Time: 2ms. http://localhost:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0&reqformat=json 2022-07-02 12:07:49.699 Info Trakt: Item Not fully played. Tell trakt.tv we are no longer watching but don't scrobble 2022-07-02 12:07:49.699 Info HttpClient: POST https://api.trakt.tv/scrobble/pause 2022-07-02 12:07:49.766 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Resume?Recursive=true&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&MediaTypes=Video&Limit=12&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.766 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=767bffe4f11c93ef34b805451a696a4e&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.766 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=0c41907140d802bb58430fed7e2cd79e&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.766 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=bdf38141c3a366eb1a2a8240d2e65e68&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.767 Debug SqliteItemRepository: GetInternalId from 0c419071-40d8-02bb-5843-0fed7e2cd79e 2022-07-02 12:07:49.769 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=9d7ad6afe9afa2dab1a2f6e00ad28fa6&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:49.848 Debug SqliteItemRepository: GetInternalId from 767bffe4-f11c-93ef-34b8-05451a696a4e 2022-07-02 12:07:49.878 Info Server: http/1.1 Response 206 to ::1. Time: 31201ms. http://localhost:8096/emby/videos/464814/stream.mkv?DeviceId=44d989c3-e15b-4676-8c9e-cbfd42664808&MediaSourceId=8cf00b245b7dbca63d81ffe5fa863261&Static=true&PlaySessionId=267437aa526e48f7a884ac5b0eb206cb 2022-07-02 12:07:49.882 Debug Server: http/1.1 GET http://localhost:8096/emby/Users/12c85f9f5a21413e91e0347775113760/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=44d989c3-e15b-4676-8c9e-cbfd42664808&X-Emby-Client-Version=4.7.5.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36 2022-07-02 12:07:50.146 Error Trakt: Error sending scrobble *** Error Report *** Version: 4.7.5.0 Command line: C:\Users\elbaz\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19044 Framework: .NET 6.0.5 OS/Process: x64/x64 Runtime: C:/Users/elbaz/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\elbaz\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\elbaz\AppData\Roaming\Emby-Server\system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Trakt.Api.TraktApi.PostToTrakt(String url, Object data, CancellationToken cancellationToken, TraktUser traktUser) at Trakt.Api.TraktApi.SendEpisodeStatusUpdateAsync(Episode episode, MediaStatus status, TraktUser traktUser, Single progressPercent, CancellationToken cancellationToken) at Trakt.ServerMediator.KernelPlaybackStopped(Object sender, PlaybackStopEventArgs e) Source: Emby.Server.Implementations TargetSite: Void MoveNext()
rodainas 191 Posted July 7, 2022 Posted July 7, 2022 If you're refering to the trakt page the link is correcttly pointing to episode 760: I see the error is while opening the link with trakt ios app, I didnt try the webpage, thanks.
Bazzu85 22 Posted July 10, 2022 Author Posted July 10, 2022 On 05/07/2022 at 16:39, Bazzu85 said: yes, here's: @Luke any feedback? can be a plugin bug?
Bazzu85 22 Posted July 19, 2022 Author Posted July 19, 2022 1 hour ago, Luke said: Are you still running into this? Hi, yes. The problem with One Piece anime is still there. From weeks the progression and watch status are not syncing to trakt. Are you been able to test?
Bazzu85 22 Posted July 28, 2022 Author Posted July 28, 2022 @Luke do you have a feedback about the problem?
