Bazzu85 22 Posted June 2, 2021 Posted June 2, 2021 Hi, tested 2 different scenarios: 1. Episode watched on emby and on trakt. On trakt removed all play. on emby executed the "import playstates from trakt". the episode is not marked as unwatched on emby Here's a video showing the problem: and the associated logs: log1.txt 2. Episode watched on emby and on trakt. On emby marked as unplayed. Executed the "import playstates from trakt". the episode is marked again as played on emby. The mark unplayed on emby doesn't update trakt Here's a video showing the problem: and the associated logs: log2.txt do you need more infos?
Luke 42255 Posted June 3, 2021 Posted June 3, 2021 Hi there, you will get a response. thank you for your patience. 1
Ptolemaeus 2 Posted June 10, 2021 Posted June 10, 2021 (edited) On 6/2/2021 at 3:56 AM, Bazzu85 said: 2. Episode watched on emby and on trakt. On emby marked as unplayed. Executed the "import playstates from trakt". the episode is marked again as played on emby. The mark unplayed on emby doesn't update trakt This is my preferred behavior, but I can't get my trakt plugin to behave this way. Instead, I can't mark anything unplayed in Emby (for a rewatch) without wiping out my entire play history for that show/movie from Trakt. Unchecking the "Update Tracked Watched History" box (which should theoretically be scrobble only) doesn't help either. Edited June 10, 2021 by Ptolemaeus 1
Bazzu85 22 Posted June 10, 2021 Author Posted June 10, 2021 here's my actual configuration: just tried now after a week from original post: 1. Sailor Moon Crystal S01E01, is watched in emby and in trakt. 2. Marking as unwatched in emby 3. Executed the "import playstates from trakt" 4. Sailor Moon Crystal S01E01, is again watched in emby
Bazzu85 22 Posted June 14, 2021 Author Posted June 14, 2021 (edited) @Luke ? I'm waiting for you! Edited June 14, 2021 by Bazzu85
Luke 42255 Posted June 21, 2021 Posted June 21, 2021 Quote just tried now after a week from original post: 1. Sailor Moon Crystal S01E01, is watched in emby and in trakt. 2. Marking as unwatched in emby 3. Executed the "import playstates from trakt" 4. Sailor Moon Crystal S01E01, is again watched in emby Why are you running the scheduled task? Don't run it except on initial import from trakt.
Bazzu85 22 Posted June 22, 2021 Author Posted June 22, 2021 (edited) Because is always worked that emby and trakt are in sync whenever I marked as played/un played. From forever if I mark as watched something on trakt, if in emby that content is found is marked as played too when the scheduled task runs.. The problem is that marking as unplayed from emby doesn't update on trakt side.. It's clear from the videos.. I was showing it using the scheduled task to point this..trakt is not being updated! Only when marking as watched there's a trakt update Edited June 22, 2021 by Bazzu85
Bazzu85 22 Posted July 1, 2021 Author Posted July 1, 2021 (edited) On 21/06/2021 at 18:58, Luke said: Why are you running the scheduled task? Don't run it except on initial import from trakt. Any news? Additionally now I have an episode that after the scheduled task keep updating to half watched state. If I go to trakt and remove all plays, emby continually set this state.. If I fix the playstate in emby (watched without half progression) the next scheduled task keep resetting to the screen situation Edited July 1, 2021 by Bazzu85
Bazzu85 22 Posted July 1, 2021 Author Posted July 1, 2021 (edited) So @Luke I make a recap... with this configuration: what DOES work in my tests: Mark an episode as watched on emby, run the "Sync library to trakt.tv", the episode is watched on trakt too Mark an episode as unwatched on emby, run the "Sync library to trakt.tv", the episode is unwatched on trakt too Mark an episode as watched on trakt, run the "Import playstates from Trakt.tv", the episode is watched on emby too Mark an episode as unwatched on trakt, run the "Import playstates from Trakt.tv", the episode is unwatched on emby too Watch an episode until the end, after that the episode is watched on trakt too What DOESN'T work in my tests: Mark an episode as watched on emby doesn't mark as watched on trakt (using the played button on episode screen, no scheduled task) Mark an episode as unwatched on emby doesn't mark as unwatched on trakt (using the played button on episode screen, no scheduled task) Watch an episode half doesn't update on trakt. Only the "Sync library to trakt.tv" scheduled task does the update. Now watching on trakt during the emby play (months ago this surely worked) Edited July 3, 2021 by Bazzu85 Updated another ko use case
Bazzu85 22 Posted July 7, 2021 Author Posted July 7, 2021 (edited) Another things that is breaking the circle of episode sync with trakt using the import scheduled task is the half progress episodes.. Check this screen for seven deadly sins s04e11 and s04e12 B Before launching the import scheduled task this was the situation on emby too After launching the scheduled task The episode half progression is lost.. Only for seven deadly sins. The Simpsons episode has the half progression So if some devs wants I can be available to do some test giving a remote desktop connection.. to add more infos from the log about the 2 situations: 2021-07-08 09:53:07.121 Debug Trakt: Episode is in Playback list Episode: 25x20 'Mattoncino come me' Series: 'I Simpson' 2021-07-08 09:53:15.081 Debug Trakt: No Show match in Watched shows list Episode: 25x20 'Mattoncino come me' Series: 'I Simpson' 2021-07-08 09:53:10.603 Debug Trakt: Episode is in Watched list Episode: 4x11 'Colui che si oppone a un dio' Series: 'The Seven Deadly Sins' 2021-07-08 09:53:15.818 Debug Trakt: No Show match in Watched shows list Episode: 4x11 'Colui che si oppone a un dio' Series: 'The Seven Deadly Sins' 2021-07-08 09:53:15.818 Debug Trakt: No Show match in Watched shows list Episode: 4x12 'Saremo tutti la tua forza' Series: 'The Seven Deadly Sins' the 4x12 episode is not retrieved from the playback list I think. but checking the screens it has to be there.. Edited July 8, 2021 by Bazzu85
Bazzu85 22 Posted July 19, 2021 Author Posted July 19, 2021 Ok, so I figured out why some episodes reset the progress when importing from trakt using the scheduled taask. Pointing to The seven deadly sins 4x12 it has not IMDB id. Adding it manually (tt14378072) . and running the import playstates from trakt.tv here's the result: so @Luke is it normal that the import task is dependent on the imdb ID? this BTW is only the first problem..the sync with trakt when marking as watched/unwatched is not working at all. For the moment I resolved scheduling like this: can you please give me some feedback? I continually giving you screens and infos about these strange behaviours.. thx
Bazzu85 22 Posted July 19, 2021 Author Posted July 19, 2021 additionally in the logs there's a great amount of record like these: 021-07-19 14:29:48.634 Info Server: http/1.1 Response 200 to 192.168.1.149. Time: 1ms. http://192.168.1.106:8096/favicon.ico 2021-07-19 14:29:51.794 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-07-19 14:29:51.812 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-07-19 14:29:51.815 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}]
Bazzu85 22 Posted August 3, 2021 Author Posted August 3, 2021 Just updated to emby server 4.6.4.0 and now: marking as watched update instantly to trakt marking as unwatched works too very good! with the trakt debug log disabled and the emby debug log enabled I continually see in the logs this entries: 2021-08-03 19:16:15.084 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.417 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.421 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.466 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.508 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.671 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}]
Luke 42255 Posted August 9, 2021 Posted August 9, 2021 On 8/3/2021 at 1:18 PM, Bazzu85 said: Just updated to emby server 4.6.4.0 and now: marking as watched update instantly to trakt marking as unwatched works too very good! with the trakt debug log disabled and the emby debug log enabled I continually see in the logs this entries: 2021-08-03 19:16:15.084 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.417 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.421 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.466 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.508 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] 2021-08-03 19:16:15.671 Debug Trakt: [{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]},{"AirDays":[]}] Well done. Thanks for the feedback.
Bazzu85 22 Posted August 9, 2021 Author Posted August 9, 2021 2 hours ago, Luke said: Well done. Thanks for the feedback. what about the empty airdays logs?
Luke 42255 Posted August 9, 2021 Posted August 9, 2021 2 hours ago, Bazzu85 said: what about the empty airdays logs? It is just logging. Are you experiencing a problem?
Bazzu85 22 Posted August 10, 2021 Author Posted August 10, 2021 13 hours ago, Luke said: It is just logging. Are you experiencing a problem? not a problem..but every time the trakt sync runs these lines are filling the log but are totally useless as are always with empty datas.. the empty airdays logs are correct?
Bazzu85 22 Posted August 10, 2021 Author Posted August 10, 2021 (edited) 2 hours ago, Luke said: It seems like it yes. Ok, but why this logs comes up with emby debug enabled and trakt debug disabled? Edited August 10, 2021 by Bazzu85 Added screens
roaku 842 Posted August 10, 2021 Posted August 10, 2021 You've enabled Emby debug logging. That's why there's a lot of extra stuff in your logs... From a lot of places. One of them is the Trakt plugin. If you want the Trakt plugin to log even more, turn on its extra debug logging too.
Bazzu85 22 Posted August 16, 2021 Author Posted August 16, 2021 On 10/08/2021 at 19:05, roaku said: You've enabled Emby debug logging. That's why there's a lot of extra stuff in your logs... From a lot of places. One of them is the Trakt plugin. If you want the Trakt plugin to log even more, turn on its extra debug logging too. so, the emby debug activate the debug everywhere, even in the single plugins. The trakt plugin debug option instead works only for the plugin?
Luke 42255 Posted August 17, 2021 Posted August 17, 2021 The plugin may have additional debug logging beyond the normal server debug logging.
Bazzu85 22 Posted August 17, 2021 Author Posted August 17, 2021 1 hour ago, Luke said: The plugin may have additional debug logging beyond the normal server debug logging. Ok, what is strange in my head is that the server debug switch influence the logs of other components like the trakt plugin that have his own debug flag.. That's all..
Bazzu85 22 Posted January 6, 2022 Author Posted January 6, 2022 Hi @Luke I'm here again to post a trakt plugin bug.. Starting from this episode with half progression: and checking that the progress is synced on trakt with Trakt.tv Playback Progress Manager (https://sharkykh.github.io/tppm/) Running the trakt import from scheduled tasks: the progress is resetted on emby side: NB: the problem is only for some episodes in next up section.. from previous months tests occurs with epidode without IMDB ID do you need some logs?
