Cheesegeezer 3106 Posted June 4, 2021 Author Posted June 4, 2021 17 minutes ago, taylorstan said: No worries. Take you time. I appreciate your work with this plug-in. look like this bug is gonna take a little more time. I have it set up that if you have an NR title then you should have your Not Rated Video in the folder named - Default.(ext) - Case sensitive. Capital D, everything else lower case. That will work until I get this fix in. Cheers But please download the new version from the server catalogue and give that a try.
taylorstan 1 Posted June 4, 2021 Posted June 4, 2021 1 hour ago, Cheesegeezer said: look like this bug is gonna take a little more time. I have it set up that if you have an NR title then you should have your Not Rated Video in the folder named - Default.(ext) - Case sensitive. Capital D, everything else lower case. That will work until I get this fix in. Cheers But please download the new version from the server catalogue and give that a try. The catalogue hasn't updated on my end yet. But I did populate the countdown bumper path and the trailer and feature presentation bumpers started to play. Hopefully that will give you a clue to that bug.
Cheesegeezer 3106 Posted June 4, 2021 Author Posted June 4, 2021 1 minute ago, taylorstan said: The catalogue hasn't updated on my end yet. But I did populate the countdown bumper path and the trailer and feature presentation bumpers started to play. Hopefully that will give you a clue to that bug. it should be instant. But you have the same Version that is available in the catalogue. I haven't done the fix yet. Your config interface looks old. You need to clear your browser cache in order to allow the new config layout to load. This is probably the reason why some things are not working. It should look like this now
crusher11 1150 Posted June 15, 2021 Posted June 15, 2021 It only plays the Default clip for the AU-R18+ classification. I'm guessing it doesn't read the + symbol properly?
Cheesegeezer 3106 Posted June 15, 2021 Author Posted June 15, 2021 1 hour ago, crusher11 said: It only plays the Default clip for the AU-R18+ classification. I'm guessing it doesn't read the + symbol properly? it shouldn't matter, as long as your rating video is named the same as the rating in emby. Oh hang on i think i have made some modifications since the last release to tighten up on that particular section, and also adding in some new features and new layout, so this will be released soon.
crusher11 1150 Posted June 15, 2021 Posted June 15, 2021 Well, the PushBullet notifications when it scanned in the file for that and the AU-MA15+ rating were "AU-MA15 has been added to Emby Server" and "AU-R has been added to Emby Server" despite the filenames being AU-MA15+.mp4 and AU-R18+.mp4. Given that it then used the Default.mp4 when I tried playing an R-rated movie, the + sign is the only explanation I can think of.
Cheesegeezer 3106 Posted June 15, 2021 Author Posted June 15, 2021 5 minutes ago, crusher11 said: Well, the PushBullet notifications when it scanned in the file for that and the AU-MA15+ rating were "AU-MA15 has been added to Emby Server" and "AU-R has been added to Emby Server" despite the filenames being AU-MA15+.mp4 and AU-R18+.mp4. Given that it then used the Default.mp4 when I tried playing an R-rated movie, the + sign is the only explanation I can think of. yup it looks like that would be the problem. are all the aussie ratings with a "+" after them or can you get AU-MA15 & AU-MA15+
crusher11 1150 Posted June 15, 2021 Posted June 15, 2021 44 minutes ago, Cheesegeezer said: yup it looks like that would be the problem. are all the aussie ratings with a "+" after them or can you get AU-MA15 & AU-MA15+ AU-G, AU-PG, AU-M, AU-MA15+, AU-R18+, AU-X18+, AU-RC. MA, R, and X have legal age barriers and the others are just recommendations (except RC, which is just flat out illegal for everyone), thus the number being included in the rating name.
Cheesegeezer 3106 Posted June 15, 2021 Author Posted June 15, 2021 55 minutes ago, crusher11 said: AU-G, AU-PG, AU-M, AU-MA15+, AU-R18+, AU-X18+, AU-RC. MA, R, and X have legal age barriers and the others are just recommendations (except RC, which is just flat out illegal for everyone), thus the number being included in the rating name. Ah, so having the Plus after the numbers is neither here nor there. So you could rename the age rating intro vids to what emby is showing for you locale.
crusher11 1150 Posted June 15, 2021 Posted June 15, 2021 1 minute ago, Cheesegeezer said: Ah, so having the Plus after the numbers is neither here nor there. So you could rename the age rating intro vids to what emby is showing for you locale. I don't follow.
roaku 842 Posted June 15, 2021 Posted June 15, 2021 5 minutes ago, crusher11 said: I don't follow. I think he's saying: Emby is the one setting the ratings string with no '+'. All you need to do is name your files to match the ratings string Emby is choosing (remove your '+''). 1
crusher11 1150 Posted June 15, 2021 Posted June 15, 2021 No it isn't. The ratings I listed above are the ratings as Emby uses them, which is why I named my files that way. I don't know where either of you got the impression it was anything else?
Cheesegeezer 3106 Posted June 15, 2021 Author Posted June 15, 2021 10 minutes ago, crusher11 said: I don't follow. ^^^^^^^^^^^^ What Roaku said
Cheesegeezer 3106 Posted June 15, 2021 Author Posted June 15, 2021 hmmmmm, i'm really lost now you said you had notifications with the plus removed, now i can see in your library they are not i only return the filename without extension, i don't modify it at all so can you look in the log and search for vantage, it should say what the ratings are it found and which one it is choosing
roaku 842 Posted June 15, 2021 Posted June 15, 2021 2 minutes ago, crusher11 said: No it isn't. The ratings I listed above are the ratings as Emby uses them, which is why I named my files that way. I don't know where either of you got the impression it was anything else? I was just clarifying what was said, not vouching for it.
crusher11 1150 Posted June 15, 2021 Posted June 15, 2021 5 minutes ago, Cheesegeezer said: hmmmmm, i'm really lost now you said you had notifications with the plus removed, now i can see in your library they are not i only return the filename without extension, i don't modify it at all so can you look in the log and search for vantage, it should say what the ratings are it found and which one it is choosing The notifications I got from PushBullet when the AU-R18+.mp4 and AU-MA15+.mp4 files were scanned in said AU-R18 and AU-MA15 had been added to the server. The PushBullet notification stripped the +. Similarly, I've been adding a lot of the "WWE Best of Raw & SmackDown" sets and every time the notification says "WWE Best of Raw was added", truncating at the & symbol. So my hypothesis is that Emby sees AU-R18+.mp4 as only AU-R.mp4 and therefore it doesn't match AU-R18+. 2021-06-15 19:49:20.416 Info App: VANTAGE POINT: Enable intros = True 2021-06-15 19:49:20.437 Info App: VANTAGE POINT:Feature Presentation Bumpers video found is emby 2021-06-15 19:49:20.437 Info App: VANTAGE POINT: Movie certification is AU-R18+ 2021-06-15 19:49:20.437 Info App: VANTAGE POINT: IMDB ID is tt0079501 2021-06-15 19:49:20.437 Info App: VANTAGE POINT: TMDB ID is 9659 2021-06-15 19:49:20.437 Info App: VANTAGE POINT: Movie Name is Mad Max 2021-06-15 19:49:20.437 Info App: VANTAGE POINT:Certification video match is Default 2021-06-15 19:49:20.452 Info App: VANTAGE POINT: MediaInfo intros found is dualmono
Cheesegeezer 3106 Posted June 15, 2021 Author Posted June 15, 2021 I will have a test with your rating system, it could be the old code which hasn't been tidied up and tightend on your version. I have done quite a bit on this specific area since the last release. Just bear with me sir
AhmedBinM 0 Posted June 24, 2021 Posted June 24, 2021 Hello All, i have an issue with only the R rated movies , vantage point cant seem to recognize it properly can someone help please on how to fix this issue, all the other ratings are working fine,
Cheesegeezer 3106 Posted June 24, 2021 Author Posted June 24, 2021 47 minutes ago, AhmedBinM said: Hello All, i have an issue with only the R rated movies , vantage point cant seem to recognize it properly can someone help please on how to fix this issue, all the other ratings are working fine, I will release an update later today. Let me know if the new version fixes. It should do. Thanks I have never seen everything match before only R and NR
Cheesegeezer 3106 Posted June 24, 2021 Author Posted June 24, 2021 3 hours ago, AhmedBinM said: Hello All, i have an issue with only the R rated movies , vantage point cant seem to recognize it properly can someone help please on how to fix this issue, all the other ratings are working fine, New version out just now.
AhmedBinM 0 Posted June 24, 2021 Posted June 24, 2021 Thank Dear for the update , but i think now the vids are not working after the update, i tried refreshing , tried other devices , install and reinstall tried to change the folder name and also setup a new one without being able to get it right. am not sure where it went wrong thanks for the help,,,
Cheesegeezer 3106 Posted June 24, 2021 Author Posted June 24, 2021 1 hour ago, AhmedBinM said: Thank Dear for the update , but i think now the vids are not working after the update, i tried refreshing , tried other devices , install and reinstall tried to change the folder name and also setup a new one without being able to get it right. am not sure where it went wrong thanks for the help,,, hmmmmmm very odd lemme check my code again apologies
Cheesegeezer 3106 Posted June 24, 2021 Author Posted June 24, 2021 (edited) 2 hours ago, AhmedBinM said: Thank Dear for the update , but i think now the vids are not working after the update, i tried refreshing , tried other devices , install and reinstall tried to change the folder name and also setup a new one without being able to get it right. am not sure where it went wrong thanks for the help,,, you should have an update on the server catalogue now. that should fix it. Version 1.0.0.2 Edited June 24, 2021 by Cheesegeezer
AhmedBinM 0 Posted June 28, 2021 Posted June 28, 2021 Sorry for the late response @Cheesegeezer I haven't responded promptly so that i could test the latest update properly , thanks for the update the issue got resolved and i have tested the other bumpers features as well and they are all working fine. looking forward for future updates with new features . thanks soo much
