MBSki 1115 Posted June 1, 2021 Posted June 1, 2021 I think this might be a bug. Can we get fixed? I like the Continue Watching image size.
MBSki 1115 Posted June 1, 2021 Author Posted June 1, 2021 Boy that is strange. Are you using Next Up (Legacy)?
vdatanet 1619 Posted June 1, 2021 Posted June 1, 2021 Just now, mbarylski said: Boy that is strange. Are you using Next Up (Legacy)? Yes, I use the beta version 4.7.0.2, but there is nothing in the changelog related to this.
Happy2Play 9811 Posted June 1, 2021 Posted June 1, 2021 Mine are the same size also. (no additional custom css)
MBSki 1115 Posted June 1, 2021 Author Posted June 1, 2021 Man thats weird. Do you get the same results in the stable version? Beta version looks ok to me too.
MBSki 1115 Posted June 1, 2021 Author Posted June 1, 2021 6 minutes ago, ebr said: Any custom CSS? Just this, but removed it and the images are still different. #pluginTiles div.emby-scrollbuttons-scrollSlider{ flex-wrap: wrap;}
Carlo 4561 Posted June 1, 2021 Posted June 1, 2021 Looks fine on mine as well. Do you get the same results in a different browser? 1
Happy2Play 9811 Posted June 1, 2021 Posted June 1, 2021 11 minutes ago, mbarylski said: Man thats weird. Do you get the same results in the stable version? Beta version looks ok to me too. That screen shot if from 4.6.1.0, but see the same in 4.7.0.2. Have you tried clearing browser cache?
MBSki 1115 Posted June 1, 2021 Author Posted June 1, 2021 2 minutes ago, cayars said: Looks fine on mine as well. Do you get the same results in a different browser? Yes, Firefox is the same and I never use Firefox.
MBSki 1115 Posted June 1, 2021 Author Posted June 1, 2021 5 minutes ago, Happy2Play said: Have you tried clearing browser cache? Yep, that didn't work either. Man this is bizarre.
MBSki 1115 Posted June 1, 2021 Author Posted June 1, 2021 3 minutes ago, cayars said: Does a server restart do anything? Tried that, and no change. If i remove Next Up, continue watching size increases. Add next up back, and continue watching size drops back down. Maybe a few more updates and it'll fix itself. Weird though.
vdatanet 1619 Posted June 1, 2021 Posted June 1, 2021 38 minutes ago, mbarylski said: Tried that, and no change. If i remove Next Up, continue watching size increases. Add next up back, and continue watching size drops back down. Maybe a few more updates and it'll fix itself. Weird though. Does updating to version 4.6.2.0 help? 1
MBSki 1115 Posted June 2, 2021 Author Posted June 2, 2021 17 hours ago, vdatanet said: Does updating to version 4.6.2.0 help? I just updated to 4.6.2 and still have the mismatched images. @cayars Anything else I can try? Some kind of Emby cache to clear?
MBSki 1115 Posted June 2, 2021 Author Posted June 2, 2021 14 minutes ago, ebr said: How about zoom or dpi settings anywhere...? Browser and monitor settings? Nothing that I've changed, no. How would that cause different rows to show up differently though? Aren't those images cached in Emby somewhere?
ebr 16334 Posted June 2, 2021 Posted June 2, 2021 32 minutes ago, mbarylski said: How would that cause different rows to show up differently though? I'm just grasping at anything that may have an effect. 32 minutes ago, mbarylski said: Aren't those images cached in Emby somewhere? No cache would have any bearing here. The size of the images on disc is not related to their display size. The UI is deciding how large to make those. What happens if you adjust the size of the browser window? At any browser size, do the images all snap to the same size?
Carlo 4561 Posted June 2, 2021 Posted June 2, 2021 2 hours ago, mbarylski said: @cayars Anything else I can try? Some kind of Emby cache to clear? Do you have a different server you can test against by any chance? While I'm sure it's a client issue it would be interesting to know if it does this on multiple servers or not.
MBSki 1115 Posted June 2, 2021 Author Posted June 2, 2021 5 minutes ago, ebr said: What happens if you adjust the size of the browser window? At any browser size, do the images all snap to the same size? If I shrink to about half the size for the browser window, the images snap to the same size.
MBSki 1115 Posted June 2, 2021 Author Posted June 2, 2021 2 minutes ago, cayars said: Do you have a different server you can test against by any chance? While I'm sure it's a client issue it would be interesting to know if it does this on multiple servers or not. Yes, the beta server is fine in the same browser.
Carlo 4561 Posted June 2, 2021 Posted June 2, 2021 2 minutes ago, mbarylski said: Yes, the beta server is fine in the same browser. So you only see this with 4.6.2 then?
ebr 16334 Posted June 2, 2021 Posted June 2, 2021 3 minutes ago, mbarylski said: If I shrink to about half the size for the browser window, the images snap to the same size. That makes me think perhaps the "responsive" logic is different for the rows...
MBSki 1115 Posted June 2, 2021 Author Posted June 2, 2021 5 minutes ago, cayars said: So you only see this with 4.6.2 then? Yes, correct. 5 minutes ago, ebr said: That makes me think perhaps the "responsive" logic is different for the rows... Seems like it.
