softworkz 5133 Posted June 17, 2021 Posted June 17, 2021 (edited) Based on the fact that you haven't posted any failure notice after 5 min, I'm tempted to assume that it's working... Edited June 17, 2021 by softworkz
UncleLeoTheDad 3 Posted June 17, 2021 Author Posted June 17, 2021 43 minutes ago, softworkz said: Based on the fact that you haven't posted any failure notice after 5 min, I'm tempted to assume that it's working... No, that is the setting I used for the failure above.
softworkz 5133 Posted June 17, 2021 Posted June 17, 2021 2 minutes ago, UncleLeoTheDad said: No, that is the setting I used for the failure above. You select MP3, and then it's stream-copying TrueHD...that's probably another bug then. Let's wait until the fix is out and retry then. Thanks.
Luke 42239 Posted November 21, 2021 Posted November 21, 2021 @UncleLeoTheDad are you still having an issue with this?
UncleLeoTheDad 3 Posted November 24, 2021 Author Posted November 24, 2021 Hi @Luke! Thanks for checking in. As luck would have it, I was able to get my hands on an old PC for free a few months ago and I switched my server over to that. Unfortunately, I can't comment on whether the problem has been fixed as a result. Sorry about that. Very happy on the PC setup. Thanks!
