knorki 5 Posted May 31, 2021 Posted May 31, 2021 Hello, maybe someone can help me with my problem. The watched status is not always synced between Kodi an Emby. Please look at the log. I have watched some tv shows. Trueblood and Blindspot are not showing as watched in Emby but Criminnal Minds is marked as watched. I am using Librelec 8.2.5 with emby for kodi plug-in 4.1.21 Any help is welcome Stefan kodi.log
quickmic 1709 Posted May 31, 2021 Posted May 31, 2021 4.1.21 is end of life. As I can see, you are still using Kodi 17. Can you upgrade to Kodi 18 or 19? If yes, install the new plugin "emby-next-gen" but Kodi 17 is not supported.
Solution knorki 5 Posted June 1, 2021 Author Solution Posted June 1, 2021 (edited) Hello, I have updated to kodi 18 and changed the plugin. Now it's working. Stefan Edited June 1, 2021 by knorki
knorki 5 Posted June 1, 2021 Author Posted June 1, 2021 (edited) Hello, the log is in the first post. But the problem is solved through the update, see my post from today Stefan Edited June 1, 2021 by knorki 1
