BlessWz 1 Posted May 31, 2021 Posted May 31, 2021 Hello developers, when I use Emby Next gen, I can access "Movies", but I cannot access the next level "All Movies" (The media library without the next-level "All Media" menu is completely normal, such as "TV Shows") This is the log file, And Shield TV screen recording, can you help me? Kodi_20210531_142151_录制.mp4 kodi.log
quickmic 1709 Posted May 31, 2021 Posted May 31, 2021 1 hour ago, ChuBlessWz said: Hello developers, when I use Emby Next gen, I can access "Movies", but I cannot access the next level "All Movies" (The media library without the next-level "All Media" menu is completely normal, such as "TV Shows") This is the log file, And Shield TV screen recording, can you help me? Kodi_20210531_142151_录制.mp4 kodi.log 179.6 kB · 1 download I see the problem, can you please try with beta version and check if the issue still exists. emby kodi beta repo can be downloaded from here: http://kodi.emby.tv/ Then install emby-next-gen from there.
BlessWz 1 Posted May 31, 2021 Author Posted May 31, 2021 6 hours ago, quickmic said: I see the problem, can you please try with beta version and check if the issue still exists. emby kodi beta repo can be downloaded from here: http://kodi.emby.tv/ Then install emby-next-gen from there. The problem has been solved, thank you very much! 1
