Happy2Play 9802 Posted May 31, 2021 Posted May 31, 2021 2 minutes ago, thesnappysneezer said: Does tmdb do tv series? Soon to be primary provider when TVDB becomes subscription only.
thesnappysneezer 2 Posted May 31, 2021 Posted May 31, 2021 7 minutes ago, zivt said: How do you lock the series ? Click on the … More, on a PC the “…” appears in the lower right hand corner of the panel image of your show in the menu. A pop up window would appear on a PC, select Edit Metadata. You can assign your own typed in Metadata here and you scroll down you can choose to lock the item to prevent future change. Photos are from the iphone app.
thesnappysneezer 2 Posted May 31, 2021 Posted May 31, 2021 1 minute ago, Happy2Play said: Soon to be primary provider when TVDB becomes subscription only. I was unaware of this, but it figures. Admins or mods at The TVDB seemed really upset that Emby and other services were using their data. I am not as familiar with tmdb’s system and quirks, but I think I might have found it lacking with information on television data in the past when I was having some issues with tvdb.
thesnappysneezer 2 Posted May 31, 2021 Posted May 31, 2021 (edited) Okay, I looked at the moviedb, creating an account there gives you the ability to log in and create an entry for this tv show. These archives are user created, so if you care enough about this show, you can enter that information, copying stuff from imdb or tvdb if you need to in regard to cast, crew, episode titles, seasons, proper order, days aired and length plus a synopsis about the program and a similar entry about each episode Edited June 1, 2021 by thesnappysneezer
zivt 3 Posted June 2, 2021 Author Posted June 2, 2021 Thanks. I opened the series in tmdb. and the problem solved. Tal 1
