Y2KFirehawk 0 Posted May 30, 2021 Posted May 30, 2021 As a preface, if it were up to me, I would ditch cable, buttttt happy wife, happy life. Emby Premier user since 2019 and was trouble-free for 1.5+ years. My OCD compels me to keep up with OS updates and Emby updates alike. Somewhere along the line (similar to this post albeit Windows), I developed audio sync issues when watching CBS and other channels that require transcoding. Stats up front... i5 Haswell ( i5-4310M), no discreet GPU, 16GB memory, SSD storage, gigabit networking running Ubuntu 20.04.02 LTS Emby 4.6.1.0 completely stock install + backup config plugin, hardware encoding enabled (defaults) SiliconDust HDHomeRun Prime (Firmware 20210210) Client devices: Roku Ultra, NVidia Shield (2017), FireTV Watching a channel such as above is happiness both "live" and recorded. Watching a channel like the above is where the audio sync issues come in. Starts out OK but as the show goes on the audio gets further behind. In my triage, I came to the following discoveries. Transcoding is done via VAAPI, not Intel Quick Sync. I reviewed the Emby Hardware Acceleration Guide to no avail. If I change to "advanced" transcoding hardware acceleration and only check the QuickSync options (avoiding VAAPI), the streams fail to start. Content that is transcoded MPEG-2 VAAPI > H.264 (AVC) VAAPI struggles Content that is transcoded H.264 (AVC) VAAPI > H.264 (AVC) VAAPI is OK Disabled hardware acceleration and, aside from the CPU utilization increase, the end results were the same. The recent Emby 4.6 release information mentions "Improve Linux QuickSync support", perhaps there are actions I need to take to support? Drivers? Anyone able to shed light? Thank you!
Luke 42246 Posted June 4, 2021 Posted June 4, 2021 Hi there @Y2KFirehawk, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
Y2KFirehawk 0 Posted June 8, 2021 Author Posted June 8, 2021 (edited) Thanks for the reply @Luke. Unfortunately I don't have data specific to CBS HD as of yet, but apparently similar behavior happens on ABC HD... The strange part being that ABC HD is "direct streaming" versus transcoding like CBS HD. I am told that the ABC watching started approximately 1830 and was fine. Around 1820 the sync between audio and video started to fall apart. Related logs attached. I am still running 4.6.1.0; did not upgrade to 4.6.2.0 yet. embyserverlog.txt ffmpeg-directstream-773668a2-7a5e-4a69-90bb-14aa6f77c89e_1.txt Edited June 8, 2021 by Y2KFirehawk
Luke 42246 Posted June 15, 2021 Posted June 15, 2021 @Y2KFirehawk are you still running into this? Have you updated to emby server 4.6.2?
Y2KFirehawk 0 Posted July 4, 2021 Author Posted July 4, 2021 Hey @Luke! Sadly upgraded to 4.6.2 and still saw the behavior. I then saw later version upgrades so I kept up with those in hope of them being the silver bullet. I am now running 4.6.4.0 and still seeing the same audio lag behavior. Attached are the latest logs. Thank you! ffmpeg-transcode-8923263c-197b-4773-a869-324a9e33b239_1.txt 20210704_embyserver.txt
Y2KFirehawk 0 Posted July 9, 2021 Author Posted July 9, 2021 (edited) So I went full nuclear option for the heck of it... Rebuilt machine w/ Ubuntu 20.04.02 LTS and did a clean install of Emby 4.6.4.0 and restored backup via plugin. (carried over series recordings via manual JSON file moves) ABC HD recordings still suffering the same audio getting out of sync problems. Edited July 9, 2021 by Y2KFirehawk
Q-Droid 1011 Posted July 9, 2021 Posted July 9, 2021 Is it only on Roku or does it happen on all of your clients - browser, mobile, etc?
Y2KFirehawk 0 Posted July 9, 2021 Author Posted July 9, 2021 39 minutes ago, Q-Droid said: Is it only on Roku or does it happen on all of your clients - browser, mobile, etc? Great and valid question! It is seen on all devices leading me to thinking it is an encoding issue at the time of recording or live playback.
Luke 42246 Posted July 26, 2021 Posted July 26, 2021 On 7/23/2021 at 2:47 PM, Y2KFirehawk said: Any thoughts on the situation @Luke? We are looking into it. Thanks. 1
Luke 42246 Posted July 28, 2021 Posted July 28, 2021 As a test, if you disable hardware transcoding on the server, does that help?
Y2KFirehawk 0 Posted July 28, 2021 Author Posted July 28, 2021 6 hours ago, Luke said: As a test, if you disable hardware transcoding on the server, does that help? Unfortunately the end result is the same. The only result is increased CPU load during recording and playback. It's worth adding that Emby performed awesome from November 2019 till February 2021 when the audio lag started on some channels, live and recorded. The only changes during that time were 1) upgrades to Emby and OS 2) firmware upgrades to HDHR 3) recent nuclear reset of Emby environment
Luke 42246 Posted July 29, 2021 Posted July 29, 2021 On 7/28/2021 at 7:32 AM, Y2KFirehawk said: Unfortunately the end result is the same. The only result is increased CPU load during recording and playback. It's worth adding that Emby performed awesome from November 2019 till February 2021 when the audio lag started on some channels, live and recorded. The only changes during that time were 1) upgrades to Emby and OS 2) firmware upgrades to HDHR 3) recent nuclear reset of Emby environment Can you please attach log file examples from that? Thanks.
Y2KFirehawk 0 Posted August 6, 2021 Author Posted August 6, 2021 On 7/29/2021 at 8:46 AM, Luke said: Can you please attach log file examples from that? Thanks. Certainly! Sorry for the delay. ffmpeg-directstream-82d4f2a4-699c-44d2-b402-4803807d3bbd_1 and ffmpeg-directstream-88e8158c-fcb8-4680-bfdc-df53f3bf923b_1 were with hardware acceleration enabled within transcoding. Audio was OK in the beginning but was separated by the time I stopped. ffmpeg-directstream-5035c669-e228-4a6b-895b-dbe07bdee34d_1 was with hardware acceleration disabled within transcoding. Audio was OK in the beginning but was separated by the time I stopped. embyserver1 was before making the hardware acceleration change embyserver and hardware_detection-63763837307 were after making the hardware acceleration change The above all noted as "direct play" likely because they were being watched "live" within the Emby dashboard, FWIW. I then unchecked the "Allow Video Stream Copy" within the Shileld/Android Emby client app Live TV settings and played a show for a bit... No hardware transcoding; saw audio lag start around 15 minutes prior to stopping onward - ffmpeg-transcode-91b32be6-dd1e-4498-a1b4-465d0b95219c_1 Re-enabled hardware transcoding again, restated Emby. Same audio lag issues presented ~8 minutes prior to stopping onward - ffmpeg-transcode-b845744a-1a81-4c42-9b5d-7ce95f8c11de_1 ffmpeg-transcode-b845744a-1a81-4c42-9b5d-7ce95f8c11de_1.txt ffmpeg-transcode-91b32be6-dd1e-4498-a1b4-465d0b95219c_1.txt ffmpeg-directstream-5035c669-e228-4a6b-895b-dbe07bdee34d_1.txt embyserver.txt hardware_detection-63763837307.txt ffmpeg-directstream-88e8158c-fcb8-4680-bfdc-df53f3bf923b_1.txt ffmpeg-directstream-82d4f2a4-699c-44d2-b402-4803807d3bbd_1.txt embyserver1.txt
Y2KFirehawk 0 Posted August 23, 2021 Author Posted August 23, 2021 Have rebooted service since above and installed latest OS updates. Swapped back to NVIDIA Shield (2015) as primary device but still seeing the same conditions.
Y2KFirehawk 0 Posted September 7, 2021 Author Posted September 7, 2021 Bump... Issue still persists? Any advice or additional data I could collect? Thank you.
Luke 42246 Posted September 10, 2021 Posted September 10, 2021 We are looking into it. Thanks for reporting.
Y2KFirehawk 0 Posted January 20, 2022 Author Posted January 20, 2022 FWIW currently running 4.6.7.0 and overall performance seems to be better. That said, there are random times the behavior appears but overall improved. Will provide more data next time it occurs.
