aleksandrab 1 Posted May 30, 2021 Posted May 30, 2021 Hello, I have livetime licence i want to upload photos from others mobile phones in home (all android) to my server emby on windows 10 my Note10+ all it's working fine but on my wife phone and my second samsung it doesn't work (both android 8.0) grand permites for file on both mobile are done server and android app up to date Could someone help please??? 1
nmkaufman 51 Posted June 1, 2021 Posted June 1, 2021 I'm having the same problem. Just realized my most recent camera uploads were from Easter, so ~ 2 months ago. LG V20 Android v8.0.0 Emby Android v3.1.94 Emby Server Windows x64 v4.6.1.0 No longer shows a list of folders to sync (same as OP) and no longer uploads anything. 1
ScottASWAJ 2 Posted June 9, 2021 Posted June 9, 2021 I have the same problem on Android 7. My device folder list is gone and nothing is uploading. I normally move my photos and videos to other folders in the parent directory and the windows server keeps track of this well. On 5/22/2021 my phone uploaded everything on my phone and then nothing would upload after that. After installing the latest windows server I started to investigate the problem and have found a solution. I installed Emby for Android 3.1.73 and the uploads are working again. I can recreate this bug by simply allowing the app to update....Folder list is gone and uploads stop. 1
nmkaufman 51 Posted June 9, 2021 Posted June 9, 2021 (edited) 10 hours ago, ScottASWAJ said: I installed Emby for Android 3.1.73 and the uploads are working again. My phone won't let me downgrade in place, and I have quite a bit of stuff downloaded to my phone I don't want to re-configure. I may just start looking for another alternative for Camera sync, for the time being. Edited June 9, 2021 by nmkaufman
Rafall 1 Posted June 9, 2021 Posted June 9, 2021 I installed for @aleksandrabEmby for Android 3.1.73 and it worked! thank you! @ScottASWAJ one update for the post @aleksandrab my with phone Samsung Galaxy A8(SM-A530F) has android 9 I'll try to update on google play and see if it still works
Rafall 1 Posted June 10, 2021 Posted June 10, 2021 i updated from 3.1.73 to up to date in google play after update on android 9 doesn't work on Android 11 all ok 1
Luke 42243 Posted June 10, 2021 Posted June 10, 2021 There's a regression for older versions of android. It's resolved in the next update to the app. Thanks. 2
