Banquero 38 Posted May 30, 2021 Posted May 30, 2021 Buenos dias, hay manera de comprobar desde cuanto tiempo hace que le estoy dando acceso a un usuario a mi servidor? Muchas gracias...
Carlo 4561 Posted May 30, 2021 Posted May 30, 2021 Hi, there is no easy way to do this from the UI. You may be able to figure this out from the config/user directory but you'll have to figure out which folder belongs to this user.
