smawdsley 0 Posted June 12, 2021 Author Posted June 12, 2021 Where do I get that? I can't see anywhere obvious on the web ui and nothing is showing up on a search in the windows search...
Luke 42238 Posted June 22, 2021 Posted June 22, 2021 On 6/12/2021 at 12:31 PM, smawdsley said: Where do I get that? I can't see anywhere obvious on the web ui and nothing is showing up on a search in the windows search... You'd have to browse the file system on your NAS to get to that folder. But before we get to that, have you updated to Emby Server 4.6.3? Can you please try that? Let us know if this helps. Thanks.
ifamily87 0 Posted August 10, 2021 Posted August 10, 2021 I am having the same issue as above I made another post too, can you please help! I have the latest 4.6.4 version, I tried to install manually, and through the app store but no luck, the server starts and then stop immediately. I cannot access any settings on emby, bad gate way or refuse to connect. I even reset the whole TNAS to factory install new TOS, and still the same issue, all the other apps works.
smawdsley 0 Posted August 11, 2021 Author Posted August 11, 2021 I ended up asking for help from Emby and they fixed it in a remote session. They were very helpful but it was a lot of work on the back end!
ifamily87 0 Posted August 11, 2021 Posted August 11, 2021 Thank you for the reply, how did you connect to them directly? I only see support through the forum. Do you know what they fixed?
ifamily87 0 Posted August 11, 2021 Posted August 11, 2021 I just fixed this, log in to your TNAS root folder and delete the emby app data folder, then re install emby again.
Luke 42238 Posted August 11, 2021 Posted August 11, 2021 I'm sorry you had to do that. We are looking into what would have caused this.
