dtr 1 Posted May 28, 2021 Posted May 28, 2021 (edited) Hi! I got Emby server 4.6.1.0 installed in docker. Emby AndroidTv 2.0.09g on both my Sony TV`s and Emby for Android Mobile 3.1.94 on my smartphone. Detected some issues: 1. when Playing any UHD movie on my 4k TV in emby, in options there are video mode (don`t know how it`s called in English version) is 1080\60 and no option to change it, while movie is 3480x2160. From smartphone there is 4k - 40mbps and it can be changed to lower resolution and bitrate. 2. I got folders with "Rick and morty" episodes, for example. I am sure, that they worked like a charm. Now if i try to open that folder from TV, emby hangs for a while, then restarts. No changes in folder itself, or access rights were made for last few months. From smartphone and browser same folder opens without issues. I detected, that any folder with episodes caused emby for android TV to restart. Please advise. Edited May 28, 2021 by dtr
Abobader 3485 Posted May 28, 2021 Posted May 28, 2021 Hello dtr, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Carlo 4561 Posted May 28, 2021 Posted May 28, 2021 12 minutes ago, dtr said: 1. when Playing any UHD movie on my 4k TV in emby, in options there are video mode (don`t know how it`s called in English version) is 1080\60 and no potion to change it, while movie is 3480x2160. From smartphone there is 4k - 40mbps and it can be changed to lower resolution and bitrate. 2. I got folders with "Rick and morty" episodes, for example. I am sure, that they worked like a charm. Now if i try to open that folder from TV, emby hangs for a while, then restarts. No changes in folder itself, or access rights were made for last few months. From smartphone and browser same folder opens without issues. I detected, that any folder with episodes caused emby for android TV to restart. Please advise. Hi, could you let us know what Emby Client you were using on the 4K TV and what type of TV it is? Thanks
ebr 16309 Posted May 28, 2021 Posted May 28, 2021 Looks like Sony TVs with built-in Android. Those TVs to not support resolution or frame rate switching. However, your 4K videos should still play in 4K. You can also change to a lower quality if you wish by selecting a different bitrate in the settings. For the hang issue, can you reproduce that and then send a log from the app right after restarting it after the crash? Thanks.
dtr 1 Posted May 31, 2021 Author Posted May 31, 2021 On 5/28/2021 at 11:25 PM, cayars said: Hi, could you let us know what Emby Client you were using on the 4K TV and what type of TV it is? Thanks Sorry for delay. TV model is KD-49xh8196, android tv Emby version is 2.0..09g (registered) - latest available @ Google Play market 1
dtr 1 Posted June 6, 2021 Author Posted June 6, 2021 On 5/29/2021 at 12:49 AM, ebr said: Looks like Sony TVs with built-in Android. Those TVs to not support resolution or frame rate switching. However, your 4K videos should still play in 4K. You can also change to a lower quality if you wish by selecting a different bitrate in the settings. For the hang issue, can you reproduce that and then send a log from the app right after restarting it after the crash? Thanks. Log file sent though emby app. Hope you can find it
ebr 16309 Posted June 7, 2021 Posted June 7, 2021 17 hours ago, dtr said: Log file sent though emby app. Hope you can find it Hi. If you provide this information, I should be able to: Quote Reproduce your problem and then use this button to send the log. Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log (in Eastern Time please - UTC -5) The name of the Emby user on the local server that was logged in at the time
dtr 1 Posted June 7, 2021 Author Posted June 7, 2021 4 hours ago, ebr said: Hi. If you provide this information, I should be able to: Hi! Log file sent, via emby app. I navigate to my movies folder, opened folder with LoveDeathAdnRobots series, then emby restarted. Right after that I submited log file. Time is: 13:39 UTC - 05:00 username: dtr, server name: atom
ebr 16309 Posted June 8, 2021 Posted June 8, 2021 Hi. This is an issue with the translation. What language are you using? Thanks.
Solution ebr 16309 Posted June 9, 2021 Solution Posted June 9, 2021 4 hours ago, dtr said: i use Russian language Okay, then this should already be fixed in the current beta of the app. Thanks.
dtr 1 Posted June 9, 2021 Author Posted June 9, 2021 (edited) thanks installed version 2.0.24g - issue no more persist Edited June 9, 2021 by dtr
