Poster Quality in XBMC
Angelblue05
I have a problem with the rendering of my posters. They look like utter crap even if the original image is 680*1000 or 1000*1500. They are all blurry. I do not have this issue with any other types of images, just posters. Is there a way to increase the quality? I seem to be having this issue as of recently (I'd say maybe the latest XBMB3C update).
Angelblue05
Ok, it is the skin. I actually use Aeon MQ5, not Eminence. I was testing to see if it was a skin problem by switching to the Eminence skin. The posters look good in Equilibrium. However, I'm still unable to stop or resume in any skin. *hint at other post* Thanks! :)
@@im85288 - I think we should roll back your change on poster size and make big the default and small up to the skinner.
Or maybe tie it to the 'indicators' setting.  Right now any unmodified skin looks like hell..
xnappo
Edited by xnappo
im85288
Sure, big will be the default. I'll post here when changed.
  • Like 1
Cool - thanks.
im85288
Ok this has been reversed, should be fine again in Eminence etc from version 0.9.532
  • Like 2
Guest
