cavalist 1 Posted May 27, 2021 Posted May 27, 2021 Some old devices support h265. So the device do direct play But it's lagging. It plays h264 well. If I want to transcode h.265 to 264, I have to decrease the quality lower than the original quality. But I don't want to lower the quality. If original bitrate is 3.4mbps, I set the quality to 3mbps. There is no difference between the two. But when original is 1.4mbps, I have to lower to 1mbps and this is huge difference as I felt. So I want the feature. Forced h.265 to h.264 transcoding without decreasing bitrate 1
Luke 42246 Posted May 27, 2021 Posted May 27, 2021 Hi there, I see. You want to be able to force transcoding without having to essentially heck it with the quality setting. 1
heciruam 30 Posted May 27, 2021 Posted May 27, 2021 Sounds like a good idea. Maybe a checkbox "Always transcode hevc" 1
