SpadeJKey 1 Posted May 27, 2021 Posted May 27, 2021 Fanart search can get the results, but the image is not displayed, I can only copy the image URL and add the logo,When I want to open from a new window, show SSL problem 1
Abobader 3485 Posted May 27, 2021 Posted May 27, 2021 Hello SpadeJKey, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Carlo 4561 Posted May 27, 2021 Posted May 27, 2021 Hi, Yes it looks like their SSL cert expired today. 2
Riggs 312 Posted May 27, 2021 Posted May 27, 2021 (edited) Reporting the issue too 500 Internal Server Error nginx/1.10.3 Server is down Edited May 27, 2021 by Riggs
vdatanet 1619 Posted May 27, 2021 Posted May 27, 2021 Yes, same here. It seems they have forgotten to renew the certificate: 2021-05-27 16:33:55.930 Error HttpClient: Error getting response from https://assets.fanart.tv/fanart/movies/601/hdmovieclearart/et-the-extra-terrestrial-5144feead1c7b.png *** Error Report *** Version: 4.6.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-73-generic (buildd@lcy01-amd64-019) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #82-Ubuntu SMP Wed Apr 14 17:39:42 UTC 2021 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 6 Data path: /var/lib/emby Application path: /opt/emby-server/system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. at System.Net.Security.SslStream.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslStream.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslStream.EndProcessAuthentication(IAsyncResult result) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean allowHttp2, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.GetHttpConnectionAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpClient.FinishSendAsyncUnbuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod)
tosa65 17 Posted May 27, 2021 Posted May 27, 2021 100% Agree... Can I possibly repair it myself? If so, how? Greetings Tommy
Carlo 4561 Posted May 27, 2021 Posted May 27, 2021 No @tosa65 it's not something you can fix. This should be simple for them to fix. Them being fanart website. 1
tosa65 17 Posted May 27, 2021 Posted May 27, 2021 4 minutes ago, cayars said: No @tosa65 it's not something you can fix. This should be simple for them to fix. Them being fanart website. You mean it's a mistake by FANART.TV?
Carlo 4561 Posted May 27, 2021 Posted May 27, 2021 The current problem with their website yes. For example try accssing https://assets.fanart.tv/ like Emby does and right now as I type this will get an error. Their SSL cert expired today so we are at their mercy until they renew/fix their cert. 1
tosa65 17 Posted May 27, 2021 Posted May 27, 2021 OK, you're right. I have found it. It shows me the same thing. OK, it makes sense... Well, I hope that fanart.tv will fix it quickly tomorrow. Personally, I think it would be better if alternative sites were also searched for ARTs.
Luke 42203 Posted May 27, 2021 Posted May 27, 2021 1 hour ago, tosa65 said: OK, you're right. I have found it. It shows me the same thing. OK, it makes sense... Well, I hope that fanart.tv will fix it quickly tomorrow. Personally, I think it would be better if alternative sites were also searched for ARTs. There are. We have more than one option for just about everything. 1
Riggs 312 Posted May 28, 2021 Posted May 28, 2021 20 hours ago, vdatanet said: Awesome memories. Thanks Sarita
