cochize1 55 Posted May 27, 2021 Posted May 27, 2021 How do I get rid of that highlight? With option to get rid all of it or just change the color to transparent and leave the circle in the left for multiselect purpose.
Happy2Play 9811 Posted May 27, 2021 Posted May 27, 2021 You want to have multi-select always visible or only on hover?
cochize1 55 Posted May 27, 2021 Author Posted May 27, 2021 Either only on hover or have it disabled completely.
Happy2Play 9811 Posted May 27, 2021 Posted May 27, 2021 Something like this div.detailsListItem.listItem-hoverable:hover, div.detailsListItem.listItem-hoverable:hover .chkListItemSelectContainer { background: none !important; }
cochize1 55 Posted May 27, 2021 Author Posted May 27, 2021 Thanks. And how to completely remove this multi-select?
Solution Happy2Play 9811 Posted May 27, 2021 Solution Posted May 27, 2021 8 minutes ago, cochize1 said: Thanks. And how to completely remove this multi-select? label.chkListItemSelectContainer[title="Multi-Select"] { display: none !important; } 1
