EatPrilosec 22 Posted May 27, 2021 Posted May 27, 2021 using a gtx 770 no decoders or encoders are availible in linux. windows shows them correctly. i have the latest stable nvidia drivers (418.181.07) uname -a: Linux pve 5.4.114-1-pve #1 SMP PVE 5.4.114-1 (Sun, 09 May 2021 17:13:05 +0200) x86_64 GNU/Linux output of vainfo, permissions: neo@pve:~$ groups emby emby : emby video render neo@pve:~$ ls -l /dev/dri total 0 drwxrwxrwt 2 root root 80 May 27 04:35 by-path crwxrwxrwt+ 1 root video 226, 0 May 27 04:35 card0 crwxrwxrwt+ 1 root render 226, 128 May 27 04:35 renderD128 neo@pve:~$ vainfo libva info: VA-API version 1.4.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/nvidia_drv_video.so libva info: Found init function __vaDriverInit_1_0 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.4 (libva 2.4.0) vainfo: Driver version: Splitted-Desktop Systems VDPAU backend for VA-API - 0.7.4 vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileMPEG4Simple : VAEntrypointVLD VAProfileMPEG4AdvancedSimple : VAEntrypointVLD <unknown profile> : VAEntrypointVLD VAProfileH264Main : VAEntrypointVLD VAProfileH264High : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD embyserver.txt hardware_detection-63757687246.txt
Solution Q-Droid 1011 Posted May 27, 2021 Solution Posted May 27, 2021 Did you follow the instructions from the Emby guide? Specifically this: Required Setup Steps Always follow the instructions on the Nvidia site, even when the installed driver version appears to be sufficient! Install drivers from here: Nvidia Driver Downloads and not from your distro. https://support.emby.media/support/solutions/articles/44001160207
EatPrilosec 22 Posted May 28, 2021 Author Posted May 28, 2021 (edited) 14 hours ago, Q-Droid said: Did you follow the instructions from the Emby guide? Specifically this: Required Setup Steps Always follow the instructions on the Nvidia site, even when the installed driver version appears to be sufficient! Install drivers from here: Nvidia Driver Downloads and not from your distro. https://support.emby.media/support/solutions/articles/44001160207 this worked, but on proxmox i also needed to install x, however it doesnt seem to nee to be running. Edited May 28, 2021 by NErdgOd56
