endian675 0 Posted May 27, 2021 Posted May 27, 2021 I am using the DLNA client in my LG WebOS TV to connect to Emby. When playing some files I am getting transcoding when that is not required. I have attached the embyserver.txt and ffmpeg logs to show the transcoding taking place. The file in question can be played directly on the TV from a USB memory stick with no issues, so transcoding is definitely not required. How can I fix this? ffmpeg-transcode-90b3d2ea-fc30-4de2-933a-d1b55ff6f758_1.txt embyserver.txt
Luke 42246 Posted June 12, 2021 Posted June 12, 2021 Hi @endian675 our LG Dlna profile is based on older models, so you'd have to edit it to include hevc support so that this file can direct play. @cayars We plan to make it more dynamic in future updates to try and detect support. Please let us know if this helps. Thanks.
endian675 0 Posted June 14, 2021 Author Posted June 14, 2021 OK, do you have any references to help me make the edit?
Carlo 4561 Posted June 14, 2021 Posted June 14, 2021 19 hours ago, endian675 said: OK, do you have any references to help me make the edit? Hi @endian675 I'm going to be doing a write up on this shortly but would like to try and help you one on one via a remote support session if possible to get this working for you. Would this be something you are able to do with us? 1
