riverboat2001 20 Posted May 26, 2021 Posted May 26, 2021 I use the NextPVR plugin to pull in 6 TV channels. Then an M3U for my other tv channels. My internet connection often drops out leaving me with just the satellite channels. So I'd like these channels at the top. However despite me changing both the Channel name, sort numbers, and tag, I cannot "force" the satellite channels to the top of the guide. This means when the internet drops out I have to scroll down loads of channels to get to a working one.
Luke 42203 Posted May 26, 2021 Posted May 26, 2021 Hi, for now the only way would be to mark them as favorite and use the sorting options in the guide to put favorites at the top. Actually if they all have channel numbers then you should be able to use the channel number sort order. But in order for that to work well, every channel will need a number. 1
riverboat2001 20 Posted May 26, 2021 Author Posted May 26, 2021 Never noticed those options before. Worked absolutely perfect 1
