MAX92 93 Posted May 26, 2021 Posted May 26, 2021 Bonjour, Quand je lis une video 4k sur Edge (version Chrome), elle n'est absolument pas fluide. Ca lag à mort. Le flux est direct, pas de transcodage. Quand je lis la même vidéo sur Google Chrome, elle est parfaite. Il y a un transcodage (CODEC Audio et Vidéo non trouvé) et donc c'est impeccable. Ma question : pourquoi je ne peux pas voir la vidéo sur Edge comme sur Chrome ? embyserver.txt ffmpeg-transcode-ad30856f-186d-44ff-b1d8-70d1d644b955_1.txt
Luke 42240 Posted May 27, 2021 Posted May 27, 2021 Hi, it looks like your server can't transcode this quickly enough. Try setting the quality setting to something 1080p so the conversion is 4k to 1080p instead of 4k to 4k. 1
MAX92 93 Posted May 27, 2021 Author Posted May 27, 2021 I'm not agree with you. All is perfect when my server transcode but on Microsoft Chrome there is not transcode, direct flow.
Carlo 4561 Posted May 27, 2021 Posted May 27, 2021 Hi, did you try what Luke said? What does Stats for Nerds show you when doing that?
Solution Luke 42240 Posted May 27, 2021 Solution Posted May 27, 2021 5 hours ago, MAX92 said: I'm not agree with you. All is perfect when my server transcode but on Microsoft Chrome there is not transcode, direct flow. Right OK, you provided an fffmpeg log, I didn't realize that was from Chrome. There is an open ticket filed with Microsoft about poor performance with hevc and Edge. 1
MAX92 93 Posted May 27, 2021 Author Posted May 27, 2021 What will be great is to force trancode, is it possible in new version ?
