letterman 40 Posted May 26, 2021 Posted May 26, 2021 Emby 4.6.1.0 When playing songs in the player at the buttom of the page, the link to show the whole album does not work. It is not highlighted on rollover at all. It would be nice to have this feature again. It worked in the past. The link to the song is highlighted, but nothing happens. Same problem within the android app (V 3.1.94).
Luke 42241 Posted May 26, 2021 Posted May 26, 2021 Hi, seems to be working just fine from here in my testing. Make sure you've completed a full library scan following the update. If you have, try refreshing metadata on the music library.
letterman 40 Posted May 27, 2021 Author Posted May 27, 2021 ok, it has to do something with inconsitances in my database. Refresh metadata does not help. I think it the same problem we already talk about.
letterman 40 Posted May 27, 2021 Author Posted May 27, 2021 solved here with emby 4.7.0.0 beta running 1
letterman 40 Posted May 28, 2021 Author Posted May 28, 2021 nevertheless a small bug in the player (database is totally correct now): If there are more than one artist, ALL artists are highlighted. They are tagged correctly. In Album view they are separated and can be selected individually.
Happy2Play 9811 Posted May 29, 2021 Posted May 29, 2021 9 hours ago, letterman said: nevertheless a small bug in the player (database is totally correct now): If there are more than one artist, ALL artists are highlighted. They are tagged correctly. In Album view they are separated and can be selected individually. Yes this is reproducible. The track MusicArtist is only linked to first Artist even though there are Multiple Artists. 1
