Armageus 78 Posted May 25, 2021 Posted May 25, 2021 I recently noticed metadata missing for a couple of Series in my Library, but haven't been able to resolve it. It occurred with the previous stable version, but have upgraded to 4.6.1.0 and still occurring. I'm using a DS1520+, running DSM 6.2.3-25326 Update 3 I've attached the full EmbyServer log showing the server startup, and then immediately performing a metadata refresh of the affected library Emby states some timeouts, but I can reach them from Client machines on the network so not sure what to look at? 2021-05-25 21:42:30.436 Error HttpClient: Connection to https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog timed out 2021-05-25 21:42:30.445 Error App: Error downloading news 2021-05-25 21:43:06.523 Error HttpClient: Connection to https://www.thetvdb.com/api/GetSeries.php?seriesname=Doctor+Who+(2005)&language=en timed out 2021-05-25 21:43:06.532 Error App: Error in TheTVDB Please help :) embyserver.txt
Luke 42243 Posted May 25, 2021 Posted May 25, 2021 Hi, yes it would appear that something is blocking all outgoing network requests that your Emby Server is trying to send out. This will prevent any internet metadata from being obtained. Can you look into this? Typical causes are firewall, security software, or VPN.
Armageus 78 Posted May 25, 2021 Author Posted May 25, 2021 Oddly though I've also rescanned my Music folder this evening to take advantage of the Music updates, and that has retreived info from Musicbrainz as far as I can see
Armageus 78 Posted May 25, 2021 Author Posted May 25, 2021 Doh... as the old rule says "It's Always DNS". DNS Server on my Synology was pointing to an incorrect entry
Luke 42243 Posted May 25, 2021 Posted May 25, 2021 8 minutes ago, Armageus said: Oddly though I've also rescanned my Music folder this evening to take advantage of the Music updates, and that has retreived info from Musicbrainz as far as I can see Is it possible that instead it was images that were already embedded into your audio files? Because I also see the same with moviedb. And even with github just to check if a new server release is available.
Luke 42243 Posted May 25, 2021 Posted May 25, 2021 Just now, Armageus said: Doh... as the old rule says "It's Always DNS". DNS Server on my Synology was pointing to an incorrect entry Ah glad you figured it out. Thanks for the feedback.
