centuryx476 9 Posted May 25, 2021 Posted May 25, 2021 Hello, File: HEVC 1080p Format: MKV Audio 1: TrueHD Passthru Audio 2: AAC 960 KB When using the first Audio track it has to be transcoded which is fine. But when I switch to the second audio track then transcoding stops but no audio actually comes out of the speakers. I play the same file on my emby app for android phone using the second audio track and it works perfectly.
Luke 42239 Posted May 25, 2021 Posted May 25, 2021 Hi there, can we please look at an example? Thanks !
centuryx476 9 Posted May 25, 2021 Author Posted May 25, 2021 Hello Luke, I have the emby log file. It contains alot of internal info. How can I pass to you more securely ?
Luke 42239 Posted May 26, 2021 Posted May 26, 2021 20 hours ago, centuryx476 said: Hello Luke, I have the emby log file. It contains alot of internal info. How can I pass to you more securely ? You can send it to me via PM. Thanks.
centuryx476 9 Posted May 26, 2021 Author Posted May 26, 2021 29 minutes ago, Luke said: You can send it to me via PM. Thanks. Sent to you Thanks
Luke 42239 Posted June 4, 2021 Posted June 4, 2021 Hi, was it major league that you were playing? Are you still seeing this with Emby Server 4.6.2?
centuryx476 9 Posted June 4, 2021 Author Posted June 4, 2021 (edited) Hello, It is still present on the latest emby server. The emby theater app is on the latest version as well. The movie was "The men who stare at goats" Edited June 4, 2021 by centuryx476
centuryx476 9 Posted June 14, 2021 Author Posted June 14, 2021 3 minutes ago, Luke said: Is it direct playing? Yes, This is me choosing the second audio track. And it is doing Direct Play
