Mavrick95590 0 Posted May 25, 2021 Posted May 25, 2021 Faut-il forcément télécharger 1 épisode pour qu’on puisse l’avoir sur Emby ou y a-t-il des noms de serveurs pour en avoir ?
Carlo 4561 Posted May 25, 2021 Posted May 25, 2021 Hi, Anything you want to appear on your Emby server has to be on it so that means you need to RIP your source material, record it via TV or provide access some other way. If you put one episode on the server you will have one episode available. If you put 100 episodes on your server, you will have 100 episodes available. Hope that helps
