rejectliu 0 Posted May 25, 2021 Posted May 25, 2021 I have noticed that the "more" button will disappear when width is reducing. I can only set zoom out to 75% for safari to let the button show. Is there any preference for this button to set ? I need "more" button more than "cc" and other button when i randomly pick a movie.
rejectliu 0 Posted May 25, 2021 Author Posted May 25, 2021 (edited) I try to add Custom Css but it be overwritten by another css videoosd.css?v=4.6.1.0 .btnOsdMore-bottom, .videoOsd-endsAtText { display: flex!important; } Edited May 25, 2021 by rejectliu
rejectliu 0 Posted May 25, 2021 Author Posted May 25, 2021 Find a temporary way for someone need this Add below two line to a ios shortcut, and type set to "use for web site" use safari launch emby web app, then click this shortcut document.querySelector(".btnOsdMore-bottom").classList.remove("btnOsdMore-bottom"); completion();
Happy2Play 9811 Posted May 25, 2021 Posted May 25, 2021 Why should there be a "More" button on the OSD, as it has nothing to do with playback? I know this issue has been posted about before.
Luke 42241 Posted May 25, 2021 Posted May 25, 2021 8 minutes ago, Happy2Play said: Why should there be a "More" button on the OSD, as it has nothing to do with playback? I know this issue has been posted about before. Some like having those functions there. Ideally the contents should actually all be merged into the gear menu.
Happy2Play 9811 Posted May 25, 2021 Posted May 25, 2021 I would never use those options from a playback stance. Who would select edit metadata from a playing item, to me there is no logic for that menu on that screen. But everyone wants something different. This is something I have never seen on a desktop so to me it would be a bug for it to appear on any other device. Yes I can force it to happen though. 2
