DeeDeeAich 0 Posted May 25, 2021 Posted May 25, 2021 Hi, I am trying to give Emby access to my external drive on Raspbian. I've searched a lot of different things and have used chmod and chown to try and give it permissions, but to no avail. I am a Linux noob so this is somewhat difficult for me. When I try to add a library from the external drive, I go to the directory that has it, but it's blank. Any help?
DeeDeeAich 0 Posted May 25, 2021 Author Posted May 25, 2021 Yes, I have. Whenever I do ls -l /media/pi/External It shows this: total 256 drwxr-xr-x 8 pi pi 131072 May 24 21:09 'Media Server' drwxr-xr-x 2 pi pi 131072 May 25 15:01 'System Volume Information' There's no mention of Emby in it. I've tried to do the su command to switch the user to emby, it says there's an authentication error. I'm not sure if I need to switch users and run this, but I thought that might be the problem. I am running these commands from the "pi" user.
DeeDeeAich 0 Posted May 25, 2021 Author Posted May 25, 2021 19 hours ago, Luke said: Hi there, have you taken a look at this? If I may add, the External drive I'm using is exFAT. I reformatted after seeing that NTFS would be an issue.
Luke 42246 Posted May 26, 2021 Posted May 26, 2021 @DeeDeeAich please review the above similar topic and let us know if it helps. Thanks !
