MBSki 1115 Posted May 24, 2021 Posted May 24, 2021 Now that Dolby Vision is available on Xbox, can you update the video player so we can play back Dolby Vision content? 2
Luke 42246 Posted May 24, 2021 Posted May 24, 2021 HI, yes it's something we can look into. Thanks. 1 1
Riggs 312 Posted May 24, 2021 Posted May 24, 2021 49 minutes ago, Luke said: HI, yes it's something we can look into. Thanks. Hey @Luke I ask. Wouldn't it be better, or possible, to enable passthrough audio instead or also?
Painkiller88 250 Posted May 24, 2021 Posted May 24, 2021 45 minutes ago, Riggs said: Hey @Luke I ask. Wouldn't it be better, or possible, to enable passthrough audio instead or also? DV is a Video HDR feature not an audio feature
MBSki 1115 Posted May 24, 2021 Author Posted May 24, 2021 Just now, Painkiller8818 said: DV is a Video HDR feature not an audio feature Audio passthrough will be needed to get Dolby Vision to work though unless Luke fixes the transcoding logic. Right now the Xbox app incorrectly transcodes supported audio formats causing all 4k to fail. 2
MBSki 1115 Posted May 25, 2021 Author Posted May 25, 2021 15 minutes ago, Riggs said: Yep! That's what got me thinking about the Emby app. 1
