richt 95 Posted May 24, 2021 Posted May 24, 2021 The guide data doesn't seem to be provided for channel 6.5 - ION in Richmond VA
richt 95 Posted May 24, 2021 Author Posted May 24, 2021 Yes, but there is nothing to map. The data is missing.
Carlo 4561 Posted May 24, 2021 Posted May 24, 2021 Hi can you give me postal code for this so I can check and then report it. Feel free to PM if you like.
Carlo 4561 Posted June 11, 2021 Posted June 11, 2021 7 hours ago, CasperTV said: Do you see channel 23.7 ION ? Who are you asking?
richt 95 Posted June 12, 2021 Author Posted June 12, 2021 Perhaps I can shed a little light on the issue. First, there is no channel 23.7 in Richmond, VA. There is an 8.2 iON, but it is not a preferred channel for my use as they broadcast in 4x3 ratio cutting off the sides of most of the program material. Channel 6.5, while it is still standard def at least broadcasts in a 16x9 format. 6.5 has been broadcasting for many months now and I had assumed that the guide data for that channel would have been eventually added, but I got tired of waiting and submitted this request. By the way, the channel lineup for 6.5 has not yet been added, so I'll continue to map it to 8.2 iON.
Carlo 4561 Posted June 12, 2021 Posted June 12, 2021 Doesn't matter, Just use the 8.2 ION guide channel for your 6.5 ION channel. It's fine to do this as both stations are ION.
CasperTV 9 Posted June 12, 2021 Posted June 12, 2021 Long as the correct info is in the guide is all that matters, my ion is mapped to direct tv I think. 1
