Luke 42237 Posted February 28, 2023 Posted February 28, 2023 5 hours ago, mastaful said: do the plugins still need to be updated to work? CoverArt doesn't work on m1 version but seems fine on intel version HI there, why exactly do you think it doesn't work?
mastaful 0 Posted March 1, 2023 Posted March 1, 2023 the overlays dont get generated if I run M1 they do if I run intel also the settings in M1 look like the photo
Luke 42237 Posted March 1, 2023 Posted March 1, 2023 Can you please attach the emby server log? Thanks.
Fixodent66 4 Posted April 2, 2023 Posted April 2, 2023 Yes to chime in on this issue also, as I too have same issue with cover art
Gecko 71 Posted May 12, 2023 Posted May 12, 2023 Hello, just a quick question about embyServer on Apple Silicon. how good/bad is the solution on such hardware currently and in the current beta ? i read that hardware transcoding was far less advanced than the other platforms but it is still able to perform Software transcoding with tonemapping using less power than an nvidia gpu ? thanks
Luke 42237 Posted September 12, 2025 Posted September 12, 2025 Hi, the tray icon for macOS arm64 will be in the upcoming 4.9 server release. Thanks. 1
DarS23 15 Posted September 18, 2025 Posted September 18, 2025 On 9/11/2025 at 8:38 PM, Luke said: Hi, the tray icon for macOS arm64 will be in the upcoming 4.9 server release. Thanks. Good to hear that the tray icon will be working on arm64. Do you have a plan to support full hardware transcoding for macOS arm64? 1
Luke 42237 Posted September 18, 2025 Posted September 18, 2025 3 hours ago, DarS23 said: Good to hear that the tray icon will be working on arm64. Do you have a plan to support full hardware transcoding for macOS arm64? Hi, that is next on the macOS to do list. 2
Canavese 7 Posted October 23, 2025 Posted October 23, 2025 My server on the M1 had been working fine but all of a sudden, some of the folders on my NAS can't be found. UPDATE: I simply logged off of emby and logged back on and all is well again. 1
