AthelriC 0 Posted May 23, 2021 Posted May 23, 2021 Hello, I recently give a try to emby,and find it very smooth and preaty so I'm already a premium member My question its if I can see a movie while I'm not connected to my network, like in plex, and how it's done, I'm running my emby on a F2-210.
Luke 42237 Posted May 23, 2021 Posted May 23, 2021 Hi, do you mean from outside your home network, over the internet?
AthelriC 0 Posted May 24, 2021 Author Posted May 24, 2021 On 5/23/2021 at 12:48 PM, Luke said: Hi, do you mean from outside your home network, over the internet? yes, I'm talking about viewing my media outside my home network, over another network like 4g etc.
Luke 42237 Posted May 24, 2021 Posted May 24, 2021 3 minutes ago, AthelriC said: yes, I'm talking about viewing my media outside my home network, over another network like 4g etc. OK Please check out the guide linked to above and let us know if that helps. Thanks.
AthelriC 0 Posted May 24, 2021 Author Posted May 24, 2021 1 minute ago, Luke said: OK Please check out the guide linked to above and let us know if that helps. Thanks. thnx im reading the guide now
AthelriC 0 Posted May 24, 2021 Author Posted May 24, 2021 5 minutes ago, Luke said: OK Please check out the guide linked to above and let us know if that helps. Thanks. I tryed what I understand on the guide (im a spanish native, not english), my router (modem, I dont use a router) have UPnP enable and the options on the guide were allready enable on my setup, I tryed to connect from my phone useing the Emby APP and my 4g internet and says an error to connect at my TNA. "we're unable to connect to the selected server right now. Please ensure its is running and try again." at the same time I'm running a movie from my TV wich is connected to my home network and it's normal, so that means that the Emby server its UP. eany advise? I'm super new to this technology D:!
Luke 42237 Posted May 24, 2021 Posted May 24, 2021 Did you go through the part about setting up port forwarding?
AthelriC 0 Posted May 25, 2021 Author Posted May 25, 2021 19 hours ago, Luke said: Did you go through the part about setting up port forwarding? no, i dont, i found it very confuseing :S
Luke 42237 Posted May 25, 2021 Posted May 25, 2021 37 minutes ago, AthelriC said: no, i dont, i found it very confuseing :S What exactly did you try? How far did you get?
AthelriC 0 Posted May 25, 2021 Author Posted May 25, 2021 14 minutes ago, Luke said: What exactly did you try? How far did you get? my modem have UPnP enable and try the automatic function
Luke 42237 Posted May 25, 2021 Posted May 25, 2021 24 minutes ago, AthelriC said: my modem have UPnP enable and try the automatic function Did you try setting it up manually as we have been suggesting?
