reddog19848 0 Posted May 22, 2021 Posted May 22, 2021 I'm unable to connect to the server. It has been working for two years and stop on last Tuesday.
reddog19848 0 Posted May 22, 2021 Author Posted May 22, 2021 I did see the server, I try putting the address. No good. I try testing the port, and it's tell me close but firewalls in computer , McAfee says good.
Luke 42203 Posted May 22, 2021 Posted May 22, 2021 OK I would suggest checking out our Connection Troubleshooter: https://support.emby.media/support/solutions/articles/44001849007-connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks.
reddog19848 0 Posted May 22, 2021 Author Posted May 22, 2021 I think it's my fault. I swapped my SSD from one Dell To another.
Luke 42203 Posted May 22, 2021 Posted May 22, 2021 1 minute ago, JohnSpartan3M said: Same here Hi there @JohnSpartan3M, are you saying you also swapped your SSD from one Dell to another?
JohnSpartan3M 10 Posted May 22, 2021 Posted May 22, 2021 15 minutes ago, Luke said: Hi there @JohnSpartan3M, are you saying you also swapped your SSD from one Dell to another? No i havent but my remote access is not working, I thought it might be the update, so I restarted for the update, but its still not working, my remote address hasn’t changed at all.
JohnSpartan3M 10 Posted May 22, 2021 Posted May 22, 2021 1 minute ago, reddog19848 said: It was working fine after the swap. I never swapped anything
Luke 42203 Posted May 22, 2021 Posted May 22, 2021 Just now, JohnSpartan3M said: I never swapped anything OK @JohnSpartan3M I would suggest checking out our Connection Troubleshooter: https://support.emby.media/support/solutions/articles/44001849007-connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks.
Luke 42203 Posted May 22, 2021 Posted May 22, 2021 2 minutes ago, reddog19848 said: It was working fine after the swap. Please see my earlier response about to try. Thanks.
JohnSpartan3M 10 Posted May 22, 2021 Posted May 22, 2021 29 minutes ago, Luke said: Hi there @JohnSpartan3M, are you saying you also swapped your SSD from one Dell to another? 29 minutes ago, Luke said: Hi there @JohnSpartan3M, are you saying you also swapped your SSD from one Dell to another? The Lan works but the Wan doesn’t anymore
Luke 42203 Posted May 22, 2021 Posted May 22, 2021 2 minutes ago, JohnSpartan3M said: The Lan works but the Wan doesn’t anymore Please go through the whole troubleshooter. I know you want to just say "fix it for me', but it doesn't work like that. This is specific to your network environment.
reddog19848 0 Posted May 22, 2021 Author Posted May 22, 2021 I have try everything you have post tow day ago
reddog19848 0 Posted May 22, 2021 Author Posted May 22, 2021 (edited) when i use CanYouSeeMe.org, It says blocked. I checked the fire wall and port forwarding. Edited May 22, 2021 by reddog19848
JohnSpartan3M 10 Posted May 22, 2021 Posted May 22, 2021 33 minutes ago, Luke said: Please go through the whole troubleshooter. I know you want to just say "fix it for me', but it doesn't work like that. This is specific to your network environment. Im not that type of person but it is alarming that all of a sudden this just happened and now its looking like i might have to learn to port forward because right now only my LAN is working
JohnSpartan3M 10 Posted May 22, 2021 Posted May 22, 2021 2 hours ago, Luke said: OK I would suggest checking out our Connection Troubleshooter: https://support.emby.media/support/solutions/articles/44001849007-connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks. I checked my ny router and the wan address for the Ipv4 ping (icmp echo) and the test succeeded 4/4 transmitted, 4/4 received, 0% loss ... I honestly dont think its on my end
Carlo 4561 Posted May 22, 2021 Posted May 22, 2021 11 minutes ago, JohnSpartan3M said: I checked my ny router and the wan address for the Ipv4 ping (icmp echo) and the test succeeded 4/4 transmitted, 4/4 received, 0% loss ... I honestly dont think its on my end What does canyouseeme.org show? Is the IP that it shows on that site the same as the IP shown on your Dashboard? Have you tried turning off any local firewall applications running on the same host as Emby Server
Carlo 4561 Posted May 22, 2021 Posted May 22, 2021 Have a look at this KB article and make sure you've done everything listed. Also make sure to read the bottom section carefully which gives you other things to check when remote access isn't working such as malware, local firewalls, VPN software, as well as how to check to see if you may be behind a cgnat (ISP blocking). https://support.emby.media/support/solutions/articles/44002137137-remote-setup
reddog19848 0 Posted May 22, 2021 Author Posted May 22, 2021 I did turn off my fire wall and the ip on dashboard canyouseeme.org showed ip and port blocked.
